Question about Hotpoint RGA520 Gas Kitchen Range
Oven will not lite it is a spectra oven
What do i do
    Problem Solver:
  • 12 Answers
This happened with my self cleaning gas range. The burners worked fine. I checked for a leak. Turns out the igniter needed to be replaced. The landlady had a warranty from Circuit City so the repairman replaced the part. Sounds like you may be in the same boat. I sure was happy to have my oven back! : )
Posted on May 14, 2008
I have a ge spectra gas range and the broiler works but oven wont work?
Check to see if the igniter glows white hot. The igniter needs to be glowing white hot before it will allow the valve to open and lite. Here is the part to order if you find it bad. Post back the results.
Feb 05, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Spectra XL44 gas oven. The stove and broil work fine but the oven will not lite the ignitor doesent even try to lite up or anything. Do you think the ignitor just needs to be changed or may there...
most likely it's just a bad ignitor,remove the ignitor and check it with a meter to be sure but it's common for the ignitor to go so i'd say install anew ignitor and you should be all set.
Apr 26, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven doesn't lite up nor does it comes on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 04, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to lite the pilot of a spectra XL44
Oven not Working or Oven not Heating
heatman101
Nov 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
No oven baking function
You need to replace the oven ignitor. The ignitor has to draw enough current to open the gas valve. Your ignitor is either broke or not working properly, so the ignitor will not lite the oven.
Jan 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ligthing the oven glow bar
you need to replace the oven glow bar take out the oven racks in the bottom of the range you will see two screws remove them remove the bottom oven pan under that is the flame spreader shield under that under it you will se the ignighter at the back of the burner bar just follow the instruct sheet with the ignighter to install and reverse just because the old bar glow-es don't mean its good just replace it
Jul 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas GE Range
need to replace ignightor in oven
Dec 30, 2007 | GE Spectra JGBP30 Gas Kitchen Range
The oven won't light, it is a gas oven. The top (broiler) lights but the oven won't light. Thank you.
Chances are the oven ignitor will need to be replaced.  Look and see if it glows.  If it does then it is weak and not opening the gas valve to lite.  Let me know what you find.
Oct 20, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Hotpoint RGA520 Gas Kitchen Range Logo
83 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
