Question about Electronics - Others
Manual for bravia kdl-40x2000 - Electronics - Others
  • 718 Answers
SOURCE: i need a manual for sony bravia KDL 40W4100. Where
KDL 40W4100
Go to;
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL40W4100&LOC=3
and click on the manual you need. Several are listed.
Posted on Apr 12, 2009
  • 8457 Answers
SOURCE: I bought my tv sony bravia KDL-40X2000 2 years ago
Ur power supply board it dying will be dead,must replaced.
Posted on Dec 20, 2009
SOURCE: Need remote code for TV Sony Bravia KDL-46W4500
I tried out a few of the numbers that were posted and the "0000" number worked.
Thanks anyway
Posted on Jan 03, 2010
  • 3247 Answers
SOURCE: MANUAL FOR BRAVIA KDL-37V5810
Try to download manual from
http://www.sony.co.uk/product/t32-v-series/kdl-37v5810/tab/manual
Good luck.
Please rate the answer if you are satisfied. If not let me know.
Posted on May 24, 2010
ginko
  • 19396 Answers
SOURCE: I have a Sony Bravia
Hi.
If the red light stays on and TV does not start up, then the TV is in protect mode because an incorrect voltage has been detected.
If the TV instead comes on with the remote, but there is no picture, problem is usually the inverter or in some case the input.
If the TV comes on in stand by ONLY if you use the main switch on TV, then comes with no picture of sound using the remote, that means that the main board is not operating. This may happen because of a defective main board (A board), because of a defective PSU not powering the main board correctly, because of a short in a different board (often the inverter, the tuner or one of input boards).
Other part that may fail is the TCon board, which function is controlling the timing of the LCD panel. This board is difficult to test, but when it fails you usually get vertical lines, false colors or other video defects shortly before the TV shutting down.
If the problem happens only occasionally, check also the wall socket. Bad wall socket grounding will cause malfunction.Ensure that earth and grounding is OK. Test the TV with no devices connected, and using an extension and a different socket.
Most of the times the problem is a defective PSU or a defective main board. Parts must be tested by a technician to find the fault.
Here the first step of testing explained: How to test an LCD TV
To book a qualified technician contact your Sony local number:Customer Service Helpline.
Here parts.
Regards.
Ginko.
Posted on Feb 20, 2011
I need a user manual for Sony Bravia KDL-26V4000
Hello Mr.Daniel,
Here's the User Guide in pdf [35685kb] for your Sony Bravia KDL-26V4000
User Guide 2 in pdf[6330kb].
Hope this helps.Thanks!
Please vote this answer if helpful.
Dec 18, 2011 | Sony Televison & Video
Do not have user manual and need to run setup
Click Sony Support to download user manual of KDL-32XBR6
Manual has detailed info about initial setup.
Mar 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony Bravia KDL 40X2000 HDMI both cutting out
Sounds like a handshake problem with the HDMI outputs on the devices. I have never seen BOTH HDMI inputs have the problem. It could be a problem in the TV where the HDMI signal is processed or the HDMI jacks may have been stressed and this is why you have an intermittent problem. By stressed I mean that the jacks have been bent by inserting the cables wrong or pulling up or down on the cables when they were plugged into the unit.
Jul 20, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Kdl-40s3000 hdmi settings
JUNH-THE HDMI CONNECTIONS ARE VERY FRAGILE I'D RECOMMEND SUPPORTING THEM ANY WAY YOU CAN.THE HDMI INPUT ON TV IS POSSIBLY DAMAGED BY NOW AND MAY NEED REPLACING.JOE TV
Nov 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Electronics - Others Logo
47 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
