Question about Amana ACO1860 Microwave Oven
My touch keypad does not work correctly - Amana ACO1860 Microwave Oven
My frigidaire model # ffmv164lsa microwave oven keypad does not seem to work. Some times it goes on by itself. Or if you unplug it 05 will go on. Cant set the clock. or if touch anything nothing happe
The answer you seek is to replace the keypad. Your unit is Stainless for you would have to replace the console as one piece part number 5304477377 I this helps. Good Luck
Apr 19, 2014 | Microwave Ovens
My MMV5165BAW displays *** with micro, AM/PM, help..etc under each x. Display flashes this msg. Touch pad will not work, but when it displays to set the clock, touch pad will work. After setting clock
There may be grease or moisture on the the control circuit board, especially in the are where the keypad strip plugs into the board.
Or there may be a pad stuck on th keypad.
See the owner's manual here in case that might help you.
Otherwise, the controller assembly may need repair, which is usually economical.
Jan 30, 2013 | Maytag MMV5165 Microwave Oven
I have the SE code on my Samsung microwave. I have replaced the touch pad but the code remains. Any further advice? What is the purpose of the second tail on the pad; not the one that goes into the plug...
Hello & Welcome to FixYa
SE or 5E means shorted keypad and to solve this problem the keypad needs replacement, if it has already been replaced then it is better to replace the ribbon cable connecting the board. Please get back to me if you have any other questions.
Kevin
Aug 26, 2011 | Samsung MW1080STA Microwave Oven
My stove is a frigidaire gallery series and my oven won't at all. Error F7 pelase give me a solution
f7 normally is a control issue either the touch pad or the control board inside the unit... turn the breaker off to unit and try to run your hand over the keypad pressing firmly on all the button ..reset the breaker afterwards usually a 50 amp ciruit and see if it still does it.. the ribbon cable on the touch pad has either failed or the control board itself... common problem with these units.
you may luck out as sometimes the keypad will get stuck and by resetting will correct problem...
Jan 13, 2011 | Microwave Ovens
I have samsung microwave model number ME 1240SC. my front panel touch screen is not working properly, when i press the keys it is not working. so i think i need to replace the touch screen. so please...
That model does not user a touch screen, it actually uses a standard membrane keypad.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then try it again.
If it's still not responding, I would suspect your membrane keypad has failed.
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
And I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you wanted to order a new membrane switch / keypad, the part number is DE34-00145F and you can order it from the Pros here. They're our favorite supplier.
Otherwise, this is a pretty standard 1200W microwave, and you may find it better to simply replace it instead of repairing it.
Dec 03, 2010 | Samsung Microwave Ovens
What does the F3 alert indicate for a GE JES1238WH001?
F3 is a shorted keypad. Unfortunately you need to replace your touch pad to correct the issue. This can happen sometimes from moisture getting into the keypad from boiling water, or it can happen for no reason at all.
Sorry there is no parts available for the microwave.
Good Luck please rate 4 thumbs up and please leave a testimonial
Oct 30, 2010 | GE Microwave Ovens
I touch the touch pad and nothing happens
Hi!!
Try unplugging unit from the wall outlet for 5 min. If the key pad still do not respond, it may have become defective they are not fixable. Replacing the key pad it is often more expensive then buying a new unit.
Spills and directly spraying cleaner solutions into keypad will eventually cause it to fail.
The correct way to clean the front of your microwave is to apply a small amount of the cleaner solution to a cleaning cloth and then wipe the keypad clean
Show your appreciation with a 4 THUMBS Rating for answering your FREE question. Thank you for using FixYa
Oct 03, 2010 | Samsung MT1088SB 1000 Watts Convection /...
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Kenmore microwave
The Keypad is a Circuit.Each of the Function Buttons is a switch. The same "Touch" Techinology as is used of your TV Remote Control Pad or your Telephone. It would appear that your Keypad Circuit is Open, not allowing touch commands to reach the Control Board.The Keypad will have to be replaced. Best done by a Professional. I have seen "Rare" cases of a defective Door Switch causing such symptoms.
Jan 26, 2008 | Microwave Ovens
Amana ACO1860 Microwave Oven Logo
19 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
