Question about Samsung N150 Netbook
N150 do not recognize ssd - Samsung N150 Netbook
HOW TO RECOVER HDD
If you mean an SSD, insert your Win7 disc and initialize your new hdd or ssd before you can format it.
Jun 30, 2014 | Microsoft Windows 7 Ultimate for PC
Dell precision 530 bios ssd
This is a little bit long shot, but check also if there is an updated firmware for the SSD (you will need access to another machine in order to upgrade it). I will look up if I find either a bios for the Dell that is working or another solution
Mar 23, 2014 | Computers & Internet
P2120 does not recognize SSD
Did your SSD come with a driver CD? If so, install the driver on your LifeBook. If you do not have a driver, go to Computer => System => Device Manager, right click on the drive and select "Update Drive Software". If the drive is not in the list, and the drive is a USB drive, then go into the BIOS setup (typically press F2 on powerup) and enable USB drives.
Nov 16, 2013 | Fujitsu LifeBook P2120 Laptop DC Car...
Acer aspire m3-581TG replaced hdd with ssd but bios doesn't see it.
will dude this notebook was build for hdd and trying to convert it into ssd has a lot of job to do and heck bios will really not be able to recognize it
Jan 05, 2013 | Acer Aspire One PC Notebook
Trying to start computer with SSD and HDD, NOT happening!
Have you tried going into the bios to see if the ssd is recognized and have the computer boot from the ssd So connect the drive and put your windows disk in and install to the ssd During the install it will scan for drives and ask which drive you want to install on Make sure you check the boot options in the bios to allow the connect drive
Nov 23, 2012 | Computers & Internet
I see your point. But if I decide to place an SSD hard drive, will Windows 7 recognize the other hard drive which is not SSD? Please respond ASASP
Windows should not discriminate one way or the other. Just make sure both drives appear in BIOS first.
I guessing you want the OS on the SSD? Load it first, then treat the 750GB SATA as a secondary hd. Just a suggestion if it gives you problems.
Oct 25, 2012 | Computers & Internet
Fn keys
There is a program called easy display manager.
and install and update us ur feedback
Apr 17, 2012 | Samsung N150 Plus 101inch netbook
Cannot install whs on ssd using flash drive
I would suggest cloning the OS install.
Install the OS on the 80GB SSD with the Foxconn board that is giving you troubles with the 40GB SSD. Then clone the drives and swap SSDs.
WHS 2011 probably will throw up a flag stating that it needs to be reactivated because of hardware changes, but it should go smoothly.
Dec 23, 2011 | Foxconn (M61PMP-K) Motherboard
Shuttle SP35P2 Pro barebone system doesn't identify a SSD drive
If the SSD card is designed for a Dell, then this card is a proprietary card that only works with Dell.
Apr 06, 2009 | Shuttle SP35P2 Pro Barebone
Samsung N150 Netbook Logo
23 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
