Question about Lionel (31956) Thomas The Train Set
My remote will not communicate with the engine ? Can this be fixed
My remote control is not responding on my vizio tablet howdo I fix
remote is not responding probably because remote sensor of your Vizio tablet is defective or because the remote itself is defective.
Good luck.
Jan 05, 2012 | Android Apps
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
Ht-c6730w problems remote not communicating
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper
than the vendors.
May 07, 2011 | Samsung HT-C6730W Theater System
My TV does not respond to the remote. I can only turn the tv on and regulate the sound by pushing the bottons on the TV
IS it a universal remote? If yes, remove the battery, wait for 10 seconds or more, fix the battery back in and re-register the remote with the TV by entering the code. But it the remote works with the TV without code, try again. If this doesn't fix the problem, please read further.
Try the remote with new batteries, ff new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
I hope the above makes sense to you.....
Good luck.
Apr 04, 2011 | Televison & Video
I have a Rheem tanklees water heater, model RTG-74XN-2. The remote shows the following error code. C4 then the number 76 then C4 then 76. What does this code mean??
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Nov 06, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
GEOTRAX REMOTES ARE NOTE COMMUNICATING WITH TRAIN ENGINES. SET HAS BEEN IN STORAGE FOR A YEAR. WE SET UP AND CHANGED ALL BATTERIES, HOWEVER, REMOTE DOES NOT MAKE THE ENGINES MOVE. REMOTE DOCKING STATION...
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets stuck and hitting it will get it going. All three engines are working now.
Oct 17, 2010 | Fisher Price Geotrax Remote Control...
The up button on my dish remote is not working. I have to push real hard to get it to move upwards on the channels.
Assuming you have fresh batteries and nothing is blocking the remote from communicating with the IR eyes on the receiver than you need a new remote most likely.
Thanks for using Fix Ya.com.
Oct 16, 2010 | DISH Network IR Remote Control
2007 chevrolet suburban check engine light came on after "tighten fuel filler cap" message, also the remote start wont work now, pep boys says they cannot communicate with obd II scanner and it must be an...
The OBDII connector is on the same circuit as the cigarette lighter. A lot of times a cell phone charger or other device will blow the fuse and cause the scanner not to power on or communicate. I would just double check the cigarette lighter fuse. Also, maybe try a different place. Pep Boys isn't exactly known for hiring the most qualified technicians.
As or the remote start. It isn't working because of the check engine light. For some reason on late model GM vehicles, having the check engine light on disables the remote start system. Once the problem is repaired and the codes cleared the remote start will work again.
Jul 17, 2010 | 2007 Chevrolet Tahoe
How do you fix the key less remote ,... its broken
You might be only needing soldering, so I would suggest that you take it to a guy who knows about fixing electronics and they should be able to fix it. If the remote is not communicating then you need to call the dealer to tell you how to reprogram your remote to communicate with the alarm module in your car. hope that helps.
May 29, 2010 | 2007 Nissan Quest 3.5 Minivan
Service 4 wheel drive, service electronic brake warning
This is caused by by a bad ignition switch. According to the dealer the ignition switch contains an antenna that many of the sensors use to communicate with the vehicle, as well as the key fob. When the switch starts going bad the vehicle computer losses communication with these sensors and starts producing codes which include the 4wd and the electronic brakes. My fiance has had the same issues with her Grand Cherokee as well as the key fob not working, the remote start not working, the service engine light comes on, the door chime will sound when the key is NOT in the ignition and the lights are NOT on, as well as numerous codes usually relating to loss of communication with one system or another. All of which are fixed once the ignition switch is replaced. Unfortunately, this usually only fixes the problem for a short time (weeks or maybe a few months) before the piece of junk ignition switch fails again and it all starts over.
Jul 15, 2008 | 2005 Jeep Grand Cherokee
Lionel (31956)  Thomas The Train Set Logo
Top Lionel Crafts & Hobbies Experts
freddyfox
J.D. Browning
J.D. Browning
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
