Question about Acer Computers & Internet
Model ms2372 does it have a cd drive and how to open it
How do I insert CD in computer? It doesn"t seem to have an open slot.
If there is no "Open" button for the drive then normally they are opened by pushing on the DVD/CD tray itself momentarily. It only needs a short positive push and the drive tray should slide out.
Dec 28, 2014 | Acer Aspire Computers & Internet
Gateway MS2370
I chatted with a Gateway rep - he said that although it sure looks like a drive door, there is no optical drive (CD or DVD) in the MS2370 model. But, no problem, he continued - just use a USB driven external optical CD or DVD. Luckily we have an external drive, guess that's what any other people who looked at this model (saw in Target) and assumed what looked like a drive was a drive door. Guess they just had the basic case with an opening for a drive they simply covered over to leave us all frustrated at trying to open it.
Nov 14, 2013 | Computers & Internet
Hi,i have notebook acer aspire 5738zg. i have problem to opein cd drive when ever i try to open its taking tomuch time and after that i cant open it what i have to do
Hi our cd drive is probably stuck try tipping the laptop differnet ways to get it unstuck if that doesnt work take the back off the laptop remove the cd drive this is quite hard on laptops and you should search google for a guide for your model. unscrew the cd drive and push the drive open and closed this should get it moving put it all back together and open ta da it works lol hope it helps
May 07, 2011 | Lifetime Acer Aspire 5738ZG Replacement...
How do i get the cd drive to open on an acer aspire ax3400-b4802??? as if i wanted to put a cd in it...i can see where it goes but theres no opening?
It depends on the drive model but there is usually a 'button' on the drive door: while the unit is power up, just press it to open the cd/dvd drive bay.
Hope it helps.
Apr 27, 2011 | Acer Aspire 5100-5033 Notebook
Will nit read games or movies. keeps saying open tray
This is almost certainly a problem with your CD drive. If you're under warranty, you can most likely have Microsoft repair it. If you're not under warranty, you can try opening it up and adjusting the lens/magnet in your CD drive. The worst case scenario is you have a dead CD drive. If your CD drive is an older model, you'll probably have to get a new 360. If it's a more recent model however, you can have a local repair shop install a new one for you for a fee. If you want to open it up and have a look, I can explain how to do it. Let me know and I'll give you the details.
Oct 18, 2010 | Microsoft Xbox 360 Console
Dvd/cd ram not opening cd
You can try to delete upper and lower filters for your system. go to start>run>type in regedit click ok> start looking for this parth HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318},when click on the folder look on the right column and look for upper/lower filters and delete it. restart system. Try updating the firmware of the optical drive depending on the model. if you want to chekc the model of your drive go to device manager right click my computer>select manage>select device manager then lookf or cd /dvd .
caution:be careful with deleting registry for your system this might affect your operating system functionality.
Jun 25, 2010 | Dell (0F146) Internal DVD Drive
My cd dvd drive is not open , tell me about cd drive open
First you need to provide more details, it's not open when the computer it's running, when the computer it's shut down...in first case you can go right click on the cd-dvd drive in my computer, and click the EJECT task, in the second case(can be used in the first one also) you can just insert a paper clip in to the tiny hole on the cd-dvd, and press the paper clip..it will mechanical open the cd-dvd drive. If you have a laptop, some models, like IBM, Gateway have on the back of the laptop a small button, liket he battery one that you can press and the cd-dvd will pump by itself.Good luck. www.nydatapc.com for more help.
Apr 13, 2010 | Compaq Laptop / Notebook Video-336970-001...
DVD Drives support
Your Laptop Model no does not seem to be valid. However asuming that you are using HP Laptop, check the below Link and find out your competable DVD drive
http://www.bixnet.com/hewhp.html
May 28, 2008 | Computers & Internet
Laptop dvd drive door will not open
update the firm ware for this drive if that is possible. This will rewrite the eprom data and hopefully restore lost functionality.
Feb 11, 2008 | Computers & Internet
CDDVD RW drive won't open /won't burn CD
Drive is more than likely fried. It's not uncommon to have DVD/CDRW drives or any burning drive go bad especially if you use it frequently. Check www.newegg.com for a replacement they shouldn't be more than 30 dollars for a decent model now.
Jan 09, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
