Question about Tanita 2204 Body Fat Scale
Homedics scale SC-411 - put new battery in as scale stopped working. still not working. what do I do next?
Replaced batteries and scale does not register weight, but just races through numbers and then "Err."
I have same problem with my scale. New batteries work for a few days. I'm throwing this thing out.
Oct 09, 2015 | Homedics SC-405 Glass Digital Scale Silver
Need instruction manual for my digital scale homedics sc512
Found the Link http://mx.homedics.co.uk/cms/mx/manuals/Bathroom/SC-512-0EU_IB.pdf
Apr 12, 2015 | Homedics SC-512 HealthStation Body...
I have a homedics SC-512 scale, I changed the battery and it says err 3?
Here is a link to the manual. I has been hard to find. http://mx.homedics.co.uk/cms/mx/manuals/Bathroom/SC-512-0EU_IB.pdf
Aug 11, 2012 | Homedics SC-512 HealthStation Body...
I changed the batter in my homedics scale model #sc-535 1606 and noe it does not work
Open it again and make sure the battery is in the correct angle..... I have made this mistake from time to time
Sep 12, 2010 | Homedics SC-405 Digital Bath Scale
The Homedics SC 380 scale said low battery. After the battery (3V DL 2032) was replaced nothing works (does not turn on). Why would this happen? Is there a reset button or a button that turns it back on?
The same happened with me, but here is what I did and it worked. I took the new battery out and set the setting on the bottom of the scale to Stone, put the battery back in. Now when I put the battery back in I made sure the plus on the battery was the last part to go in, it faced the part inside the casing that needs to be pushed back when you take out the battery. Once it was in I put the setting back to LBs and it worked. Don't know how but I was just as frustrated and it worked.
Jan 28, 2010 | Homedics Health & Beauty
The Homedics SC 380 scale does not work after the battery insert
ensure the battery contacts are clean, if they are corroded it wont work. You may have to buy a contact cleaning spray or brush to do it.
Jan 28, 2010 | Health & Beauty
Battery replacement
Check to make sure you inserted the batteries correctly the plus signs should be up. If that doesn't work I reccomend contacting homedics customer support as something is worng with the scale that you cannot fix there is a lifetime limited warranty on the product so its better to let them try to fix the problem.
here is support contact information
http://www.homedics.com/products/support
here is the information on the warranty
http://media.homedics.com/warranty/warranty_life.pdf
Apr 01, 2009 | Homedics Elegant Glass LCD Digital Scale...
Scale wont work
Sounds like a warranty issue. I would try to return to place of purchase if not here is web address on manufactures site with instructions on warranty.
http://www.homedics.com/products/warranty-returns
Nov 25, 2008 | Homedics SC-405 Digital Bath Scale
Tanita 2204 Body Fat Scale Logo
67 people viewed this question
Top Tanita Health & Beauty Experts
Tre Elkins
Ankit Chandel
Ankit Chandel
Tom Chichester
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
