Whirlpool wfs1071aw trying to connect the pump hose after cleaning it not sure how to connect it back up and where does the ball fit in?
  • 159 Answers
SOURCE: Washing machine will not drain
The ball is part of the system. They float up when there is water in the washer and as it drains if go's down. It sounds to me you must have a blockage somewhere, if you know the pump is operating in the drain cycle. If your sure there is no blockage and the ump is working I would replace the pump. On electric pumps they may work but if the impeller is worn from something that got into the pump it will spin but not pump the water out. Hope this helps you.
Posted on Jul 12, 2007
  • 91 Answers
SOURCE: Red light on - clean pump
remove bottom panel 3 screws7mm once removed access to pump im front clean and reinstall thats it
Posted on Jan 03, 2009
  • 67 Answers
SOURCE: Clean pump red light on Whirlpool WFS1071AW, How do I?
TAKE OUT THE SCREWS ON THE BOTTOM PANEL AND ON THE INSIDE OF THE MACHINE NEXT TO THE PUMP YOU WILL FIND A PIECE OF PLASTIC WITH A SMALL HANDLE, ROUND IN SHAPE, PULL THIS OUT AND CLEAN THE FILTER
Posted on Aug 11, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Whirlpool Duet F02 code
Hello there
You are pretty close
here is the fauilt code and the procedures that you can take to troubleshoot Hope this is very helpful for you
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Posted on Dec 26, 2009
  • 949 Answers
SOURCE: How to
I hope I am not sending this twice but it had trouble the first time, anyway here you go. If this is to small to read let me know and I can send you via email the entire book.
Posted on Apr 20, 2010
How do I clean the pump on a Whirlpool 6th sense frontloader
The pump filter is situated behing the white plastic kick strip on the front at the bottom of the machine.
Instructions for use Whirlpool UK
Sep 19, 2014 | Washing Machines
I have a WFS1071AW-7.5kg. It is stopping mid cycle and showing a red "Clean Pump" light on the front panel. Where is the pump and how do I clean it? Your help would be appreciated.
The pump is hidden below the removable kick plate at the bottom of the machine. Hold the plinth on either side and pul it downwards and outwards to remove it. The filter is unscrewed by turning anticlockwise.
This is covered in page 11 of your manual, a pathetically poor scanned PDF copy of which is supplied by whirlpool Australia if you go to this web address:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001/DOCTYPE/IFU/DOCLANGUAGE/AU
Enter WFS1071AW As the commercial code and select language ENGLISH
Note: This model has no drain hose to get rid of residual water, suggest you tip the machine back 45 degrees and have a towel ready to catch any leaked water.
Aug 23, 2011 | Whirlpool Washing Machines
About one minute after starting machine (Whirlpool Duet WFW9600T01) the machine flashes "SUDS" for a couple minute or so, then the machine locks up with the F35 code. The only way to open the...
this is a suds lock and a very nightmare of a call....... are you using high effeciency soap and do you ever run a clean cycle ....... i prefer an affresh cleaning tablet once a month...... first things first need to drain all water out of washer threw drain hose connected to drain pump .... then check for any float obstructions at bottom of outer tub to drain pump large 4 inch ruber hose at bottom of tub with a plastic ball in it make sure there isnt any lint causing float ball not to seal in pump vacum... then reinstall and reconnect hoses then check pump filter sump trap for debris and reinstalll next open washer and install an affresh cleaning tablet and select hotest water cycle or clean cycle if washer is equipped with this feature and close door and let washer run ...m if code comes back you make have to repeat draining and pump steps a COUPLE OF TIMES TO REMOVE EXCESS SOAP BUILDUP..,. CAUSIN SUDS ERROR LOCK CODE.....
Jan 24, 2011 | Washing Machines
Clean pump light keeps coming on the machine is a WHIRLPOOL WFS1071AW 7.5KG
Possible thaat the drain pump is clogged and must be cleaned out as the filter is choked.
so remove the drain and have it cleaned and reset , also check you inlets and drain hose.
Sep 30, 2010 | Washing Machines
How to ''Clean pump'' on whirlpool WFS1071AW
Apr 19, 2010 | Whirlpool Washing Machines
Power Washer has no pressure, any ideas
1. If you have an inlet chemical injection valve make sure that the hose is intact and that the valve is closed.
2. Purge all air from the line by holding the nozzle actuation lever open until all air has been purged. When you connect the water supply hose turn it on before connecting the high pressure hose and let the unit self purge to the pump outlet high pressure hose fitting. Then connect the high pressure hose.
3. You could have a stuck spring and ball inside the high pressure head of the pump. You can tip the unit on its' side and add a substantial amount of WD-40 to the water supply hose fitting in an attempt to free the springs and balls.
4. Try BRIEFLY running the unit without the hose connected to see if there is high pressure water ejected from the high pressure fitting.
5. Inlet water screen at hose connection is clogged (hose screen and rubber) Check screen for debris.
6. The water strainer is clogged. (Almost looks like an LPG regulator just after but in line of the supply hose connection to the pump)
Order of troubleshooting
1, 2, 5, 6, 4, then 3.
Thanks for using FixYa!
Kelly
Mar 19, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Hello there
F/02 Long Drain
Dec 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY Whirlpool AA1400 5145 I had remove bottom drain and there is some blocking then I don't know whow comes first the ball or the rubber. Regards, OA
Hi
I hope I understood your question properly.
When you take off the drum drain pipe, you have a plastic ball and plastic ring inside the cup shaped hose which fits on the bottom of the drum.
When putting it back on, first put the plastic ring inside the cup-shaped hose. Then put the plastic ball on top of it.
Secure the hose to the bottom of the drum with the metal clamp. Make sure it is on correctly and will not pull off.
Also make sure there are no kinks in the hose leading to your drain filter.
Start a quick cycle and monitor the machine to make sure there are no leaks.
Best Regards
Ash
Nov 15, 2009 | Whirlpool AWM5145/2 Front Load Washer
Jan 03, 2009 | Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
