Question about Crafts & Hobbies
I have a Thomas and friends remote control train set. The remote is not communicating with the engine. What can I do to fix it
  • 80 Answers
SOURCE: Peg Perego Thomas Train Track Rider
I cannot promise that this is the problem, but this is where mine was broken, and you may be able to fix yours this way.
I was able to remove the plastic around the tender and access the motor. Using alligator clips, I was able to connect the battery directly to the motor, bypassing the circuit board. The motor functioned, therefore the only component that seemed to be defective was the circuit board, located behind the speaker in the engine unit.
As far as I know, the only place to buy a replacement circuit board is from www.tigerimports.com. Search for part number MEVA0024. Cost is around $15 + shipping (around $6 or so).
I should be receiving this part by the end of the week and will report if it fixed the problem.
Thanks for using Fixya. If I didn't help your situation, please DO NOT label this advise as "inappropriate".
Posted on Mar 24, 2009
Hi
Have you tried keep pressing the right hand button down. When you press the button down and hold the press, then the sounds are finished, the trains starts driving. When you release the button the train stops at once.
Posted on Jun 01, 2009
SOURCE: Have lost instruction manual for THOMAS ULTIMATE TRAIN SET byTOMY
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
Posted on Nov 24, 2009
chuky172
SOURCE: dont know how to change the battery in Thomas Jet engine.
Hey. I was looking for the same thing and found this answer on yahoo answers:
"loosen the phillips-head screw on the underside front center of the jet engine train (you might not have noticed it - it is behind the coupling magnet assembly, which you can move to the side and also has an opening to access the screw) - once the screw is loosened, you can lift up the 'jet engine' from the base to access the battery enclosure"
http://answers.yahoo.com/question/index?qid=20071225073953AAHYJKb
Posted on Jan 14, 2010
SOURCE: How do you change the
Go here for the manual http://www.tomy.co.uk/_download/IZFHDBYX.pdf but all you need to do is squeeze the top while pulling the centre wheels forward. This releases the clip on clamps and the top lifts off. AA battery required.
Posted on Nov 23, 2010
Help please. Lionel (30190) Thomas & Friends remote O gauge. Train won't move. Light comes no, nothing. I took the roof off and made sure the switch was in the on position. ??
First, check to make certain that the batteries in the remote are good.
Second, if the train has been running and the problem is new, clean your wheels and pick up roller on the locomotive, then clean the track.
Make certain that when you use the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If none of the above helps, contact the Lionel Service Department.
586-949-4100
Oct 07, 2013 | Lionel (31956) Thomas The Train Set
Cant get the steam to work on the engine have put in water and new batteries and the steam is still not working
I am having the same problem with our control steam sounds thomas train. I've been searching to no avail. If anyone can help me please leave me a message thank you!
Jan 12, 2013 | Tomy THOMAS FRIENDS REMOTE CONTROL STEAM...
Electric train set stop and goes when it goes over certain parts of the tracks do I need to clean the tracks or the wheels and what do I use to correct this issue?
1: make sure all track connections are tight.
2: clean the track using a Green 3M scratch pad
or a track eraser.
3: clean your wheels, some people use smoke fluid
on a cloth, I use alcohol prep pads,. A track eraser
can also be used. there are commercial wire brush
cleaners that connect to your power source.
Nov 05, 2011 | Bachmann Thomas the Tank Engine Train and...
Looking for track layout instructions for Thomas & Friend Trackmaster Misty Island track. Thank you
find it here
http://service.mattel.com/us/product_detail.asp?id=R9634&Ntt=R9634&Pn=1&Brand=Fisher-Price+Friends&Cat=Thomas+The+Train+TrackMaster
Nov 06, 2010 | Fisher Price Thomas and Friends...
GEOTRAX REMOTES ARE NOTE COMMUNICATING WITH TRAIN ENGINES. SET HAS BEEN IN STORAGE FOR A YEAR. WE SET UP AND CHANGED ALL BATTERIES, HOWEVER, REMOTE DOES NOT MAKE THE ENGINES MOVE. REMOTE DOCKING STATION...
I had the same problem with two of our three engines. I read somewhere that you can get them running by hitting the side of the engine against a hard surface. I can't believe it... IT WORKED! I guess the motor gets stuck and hitting it will get it going. All three engines are working now.
Oct 17, 2010 | Fisher Price Geotrax Remote Control...
Where do I put the battery for the HIT motorized Thomas train
i will try my best to help, i had the same problem with my sons as well..i was in the same situation:).You have to take the top of the train and the bottom of the train apart, seperate the top & bottom,then the battery compartment is inbetween the two..sounds confusing i know..they are very hard to pry apart.Hoped I helped!
Jul 06, 2009 | Hit Thomas and Friends Trackmaster...
Crafts & Hobbies Logo
27 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
