Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Won't dry clothes remain wet and warm
Clothes still wet after spin
it is normal for clothes to be a bit wet after spin.approximately about 80 percent of your clothes will be dry after spin. you may hang your clothes to completely dry or place it inside a drier machine
Sep 03, 2015 | Maytag Bravos 3.8 Cu. Ft. Washer
Tip
Dryer Dry Time Appears to Jump or Stall During Auto Dry Cycles
The operation of dryers during the Auto Dry Cycles is based on the moisture content of the clothes as they cycle over the moisture sensor. At the start of the cycle, the default estimated time is displayed depending on the cycle selected. The moisture sensor feeds information to the control based on the "wetness' of the clothes during the first 5 minutes of the cycle. The control then calculates and display a new estimated time making the time appear to "jump".
Recalculation happens again based on the reduction in the "wetness" of the clothes when the Estimated Time Remaining is between 15 to 5 minutes. The control will extend the cycle and display the Estimated Time Remaining unchanged if it "sees" no significant reduction in the wetness level of the clothes. The dryer will run longer than initially projected and give the appearance that the displayed time has "stalled".
Clean the sensor bars for any films or dirt build up to make sure it sends accurate information to the control. Level the dryer front to back and side to side to ensure the clothing will tumble properly and making good and proper contact with the moisture sensor bars. Check the dryer vent duct for any restriction to ensure a good air flow as the operation of the Auto Dry Cycles is based primarily on the air flow condition.
It is highly recommended to clean the lint filter before every load and make sure the dryer is grounded at the wall plug.
on May 17, 2010 | Whirlpool WED9200SQ Electric Dryer
Clothes don't dry or get warm
Ether a bad heating element,or an obstructed discharge vent. The bad element will prevent heat production, a blocked discharge will not allow humidity to escape, resulting in wet clothes. Hope this helps.
Sep 11, 2013 | Dryers
What is a dry suit and how is it different to a wet suit.
A dry suit is loose fitting apart from a sealed neck, wrists and ankles to stop the water getting in. Dry suits do not provide insulation and the clothes worn under the dry suit keep the people warm they are used more for deep sea diving. Wet suits no not keep a person dry but they are insulated to keep the person warm during water sports or scuba diving.
Jan 14, 2013 | Scuba Diving & Snorkeling
My drier was on the sensor cycle and was supposed to run for 54 mins. It was still drying over 2 hours later and the display showed there were 42 mins remaining in the cycle. The clothes were completely...
More than likely the temperature sensor has gone bad. If the unit is under warranty I would contact the dealer...otherwise you need to replace the sensor.
Sep 01, 2011 | Samsung 7.3 Cu. Ft. Super Capacity...
My maytag duet electric dryer is heating, all controls seem fine, we cleaned out the lint traps, checked the hose and blew out vent as well. The dryer keeps shutting off early before clothes are dry. They...
Your moisture sensing bars may have junk on them. The way your machine detects drynesss ir with we clothes.
As them wet clothes rub them bars they short out the board and that way it knows them clothes need a bit more time.
If thm bars get a bit of softener oem and glaze over the bars then wetness won;t be detected no more and the control won't know them thangs is wet or dry and most likely declare a No Joy.
Dec 10, 2010 | Dryers
Dryer heats up but clothes won't dry
Check that the lint filter is not blocked or that the oulet hose is not kinked
Feb 04, 2010 | Dryers
HDV6UK...clothes are warm but not drying!! help
Vent going away from the dryer is stopped up full of lint or the vent tubing is collapsed causing the hot wet air to remain in your dryer.
Nov 19, 2009 | Hoover Dryers
Clothes get warm but stay wet and do not fully
You need to check the venting. Take the vent hose off the back of the dryer and try drying a load with it off and see if it will fully dry. If so, clean the vent hose.
Nov 16, 2009 | Whirlpool GGQ8831L Gas Dryer
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
37 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
isaac johny
isaac johny
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
