Question about Vacuums
Broke hose on my bissell
My hose broke right where the attachment go on it like torn loose .can I cut the hose then try to attach it back ?
    Sergeant:
  • 239 Answers
Bissel. com actually sells the parts quite cheaply.
I have one of their "Spotbots" and you can get most of the replacement parts right on the site...
Posted on Feb 16, 2014
reddevil6
  • 1673 Answers
SOURCE: BISSELL PROHEAT SHAMPOOER WITH SCOTCHGUARD ATTACHMENT
If one attachment works ok, but another doesn't, then there must be a problem with the attachment and will have to be replaced.
Posted on Jan 06, 2008
reddevil6
  • 1673 Answers
SOURCE: Bissell Vacuum 5770 intermitent spinning brushes
Change the belt, they stretch after a short time and then it can't drive the brush roll under load. The part # is 2031329
Posted on Jun 03, 2008
SOURCE: electrolux lux vaccum cleaner hose and fitting/nozzle needed
Ladies! Go to vaccums24X7.com. They have more parts for older machines than you can imagine. They have good pix to help you ID your model if you can't read the worn spec plate. They have hoses for the 1970's-1990's old "iron horse" electrolux canister models. So does ebay and a few other sites...do a google search and you will find them. Sadly, Electrolux (the company) is more interested in selling new machines than supporting old ones...like everyone else these days. Still my old (1982) Silverado Delux really sucks, so much so in fact that it pulled the liner out of the old hose and would not pick up dirt as a result. A new hose is about $70....you can get a whole new vaccum at Wally-World for that, though as you point out they do not have the vaccum that the older machines do, but then the older machines are always needing work because of their age. I hope that helped you.
Posted on Apr 20, 2009
  • 120 Answers
SOURCE: My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Posted on Jul 06, 2009
  • 83 Answers
SOURCE: hose attachment
Your wand is getting stuck in the hose because the hose is twisted - you need to unwind it:
1) Pull the wand up as far as you can, all the way if possible
2) Stretch the hose out and unwind it, use some babypowder on the metal part of the wand and in the future, unwind and stretch the hose out after you use it
3) If you can't get the wand all the way out, remove the canister from the front, push the button where you see the 7 vertical grooves (on the opposite side of the hook that you wind the cable around) - then pull on the hook and pull the hose up and off of the machine - stretch the hose out from the bottom and pull the wand out - now apply baby powder to the metal rod and disconnect and stretch and unwind the hose every time after you used the wand to clean.
Posted on Jul 30, 2009
My kirby heritage II vacuum hose has a cut near the end of the metal nozzle. Is there a way to replace just the hose or even just cut off the damaged section and reattach to the metal nozzle?
We do carry a brand new Heritage II hose here. I do not know how you would cut and reattach the hose without losing hose integrity. You can try submerging the end in warm almost hot water and pulling off the end, cut the hose, and squeeze the end back in. But your hose will be shorter and I am not sure if it will work depending on how it is torn.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Sep 13, 2014 | Kirby Heritage II Vacuum
Remove hose from 66T6
I know how frustrating this can be. Try turning the hose and wands in opposite directions where they connect. Once the hose and wand is separated you'll be able to connect the pet hair attachment.
Here's a quick link to obtaining a copy of the user guide if you've misplaced yours:
http://www.bissell.com/user-guides/?cid=ccsocial
Feb 07, 2013 | Bissell 66T6 Pet Hair Eraser Cyclonic...
I have a bissell powerforce bagless vacuum. My
Its probably is the roller brush causing the noise.
Nov 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell Healthy Home Vacuum brush stopped working. The hose attachment works fine, just the brush on bottom. Without taking it completely apart, it shows no sign of blockage. Any suggestions? Or, will I...
You will have to remove the bottom plate to get at the brush. The drive belt either slipped off or broke, this will have to be replaced.
Nov 08, 2009 | Vacuums
My kirby vacuum just quit when I was vacuuming my car
Your Kirby has a cut off switch in the front where your hose attaches and also on the side where your bag attaches. If the plastic prong that activates the switch broke off your hose you vac will not turn on. If you put the head back on and make sure your bag is on correctly and the machine runs, you just need a hose end to fix your problem.
Oct 08, 2009 | Kirby G4 Bagged Upright Vacuum
Attachments hose won't **** but blows out
the polarity on the motor mite change with use or low suctoin
Dec 20, 2008 | Bissell 3576 CleanView II Bagless Upright...
One plastic wheel on my 3102-0 broke off
Katie, I have the same problem. I have checked and you cannot buy the wheels. You can buy the whole nozzle assembly from Sears parts for $13.99. I am going to attempt to glue mine back on but I am not optimistic because the plastic attachments are tiny.
Oct 10, 2008 | Bissell 3102-0 EasyVac Upright Vacuum
Soap/water solution pouring out on floor when trying to use hose & attachments
The attachment hose is torn right where it connects to the motor . And there should be a trigger on the end of the hose right below where it connects to the hand tool.
Oct 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
BISSELL POWERFORCE BAGLESS UPRIGHT FOOT HOSE IS TORN
Take the top cover off, unscrew where the hose hooks onto the back, then you can get to it.
Nov 18, 2007 | Vacuums
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
