Question about Sansui Televison & Video
Hi i accidentally stepped on my tv remote and changed the channel. Now my screen is white and black fuzzy. My cable box is still fine. I tried turing it on and off, reseting it changing the channel, changing the input and the channel search. Nothing is working. Please help! Thank You -Grace
  • 12 Answers
SOURCE: No Picture, sound is all static
CHECK YOUR VIDEO INPUTS. THE HD SIGNAL IS TAKING OVER ALOT OF THE ANALOG SIGNAL.MAYBE A STRONGER ANTENNA OR ADJUSMENTS MIGHT WORK AS WELL.
Posted on May 25, 2006
techman
  • 3130 Answers
SOURCE: cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Posted on Aug 18, 2006
  • 218 Answers
SOURCE: Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Posted on Jul 27, 2008
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
  • 280 Answers
SOURCE: black screen on EVERY input/channel
Turn off the closed capition
Posted on Jun 19, 2009
Channel three is missing
Hi pasu, Normally if you can get/program Chs 2 and/or 4 as well the other channels, then Ch 3 should also be programmable. If this is not possible, perhaps you can try to manually program by selecting "03" and add to the memory "+" in some brands/model. If this is still a no go, perhaps you should seek the services of qualified professional since this would apparently be an internal software problem. You can also try a hard/full reset by unplugging the TV from the mains for couple of hours or as prescribed by your TV's user manual. If the TV has Video input features, a possible temporary work around the TV's Ch3 problem is to use the Video1 or the Audio/Video INput of your TV and use an old VCR to connect to your cable box. Remove the coaxial cable from your cable box to your TV and connect it to the RF/TV INput of your VCR. Use a 3 way RCA to RCA connector (usually Yellow, Red & White) to couple the Audio/Video OUTput of the VCR to the Audio/Video INput of the TV. Select Video mode in your TV (so it doesn't matter even if you cannot program Ch3). Power up your VCR, select Ch3 in your VCR's tuner. I assume that to select channels you wish to view, you use a remote and channel selection is done in your cable box. What worries me is "...went to a fuzzy black and white screen..." which is indicative of another fault. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | Philips Magnavox SC3127N 27" TV
My RCA has a black block come up in the bottom of the screen? We have Dish Network Satellite and have programed the remote from the remote code guide. TV volume and channel changer work, but picture is a...
This has hopefully been resolved for you, but if not, here are some steps to go through. The black box that comes on the screen is usually signaling that closed Captioning is activated on the tv. Closed captioning does not run through the DISH Network receivers, so you can turn that feature off in your tv settings. The fuzzy picture could be a few things. You will want to check that all of your cables on the back of the receiver box and tv are tight as possible, and also make sure that the tv is on the correct channel. If you are in the room with the receiver, the tv will need to be on channel 3 or 4, and sometimes an input; usually video 1 or 2. If you are in a number two room, where there is no receiver, than you want to make sure that the tv is on channel 60 or 73. I hope that this helps!!!!!
Becki Barned
DISH Network Customer Service
Sep 11, 2010 | RCA F36650 36" TV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Cable on TV suddenly went to black & white (and a bit fuzzy)(some channels show faint colour). Was fine, nothing was changed, one day was suddenly B&W. TV screen is not the problem, all other cable...
Was playing around with the TV's menu and changed the Tuning Band from "HRC cable" to "IRC cable". Suddenly I have colour again. No one had adjusted any of the controls, so still not sure why one day it was fine and the next day it had gone to black and white, but changing the Tuning Band fixed the colour problem for me.
Sep 13, 2009 | Televison & Video
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Cannot get the television to get out of fuzzy screen
  • hit the channel return button on the remote
  • hit the tv/video button on the remote
  • perform a channel scan through the remote menu
  • unplug unit for over an hour and plug back in, complete initial setup by following instruction on the tv.
Jun 25, 2008 | Philips Magnavox 27MS343S 27" TV
Toshiba TV colour not working
May not be tv, could be cable or sat box. also check cables from sat or cable box.
Craig www.classtorations.com
Jun 08, 2008 | Televison & Video
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Jun 04, 2008 | JVC AV-32230 32" TV
Televison & Video Logo
13 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
