Question about Sharp MX-2300N Color Copier
How to install fuser in mx 2300n - Sharp MX-2300N Color Copier
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
3 blue screws and unlock the 2 grey lever and pull out
Posted on Jun 27, 2014
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
Sharp MX-2300N constantly sounds like it's feeding paper. It will feed paper just fine when it's actually printing something but it will still sound like it's printing something but nothing ever happ
The fuser will occasionally turn on and run to keep itself at 400 degrees. You can change the 'time to sleep' for both the fuser and overall copier through the Energy Saver admin level in the System Settings. If the fuser is running way too often, the thermistors may be insulated with a layer of toner which can be scraped off. If after a print or copy job, the machine still runs for 5 seconds or longer, you may have scrambled firmware needing a reflash.
Jun 03, 2014 | Sharp MX-2300N Color Copier
Hi
Open door on right, should be to blue screws holding the fuser unit in, remove the screws, then pull out fuser using the grey handles at either end of the unit.
Cheers
Andy
Feb 16, 2014 | Sharp MX-2300N Color Copier
Pod1_fus jam code
Jam codes should be POD1_NR (paper didn't reach) or POD1_S. (paper on the sensor flag). There's either a buildup of toner on the sensor flag just out of your fuser, a buildup of toner on the guide in the right door, or your fuser needs a rebuild. Or your 'pawls' (pick fingers) on your fuser are stuck, broken, or crooked.
Nov 12, 2013 | Sharp MX-2300N Color Copier
Where is the fuser unit located in Sharp MX-2300n
right side pull cover first and its o top and its hot
Oct 15, 2013 | Sharp MX-2300N Color Copier
H5-01
There is a paper jam most probably in the fuser unit. This causes the heater lamps delay in heating the fuser roller at the required time.
Feb 21, 2011 | Sharp MX-2300N Color Copier
Sharp MX-2300N with error code H3-00. . how do I fix it?
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Mar 09, 2010 | Sharp MX-2300N Color Copier
What is Code: H5-01 on the sharp mx 2300 copier
You need a service reset.This is a fuser problem .clr and star and hash and star fusing reset
Oct 27, 2009 | Sharp MX-2300N Color Copier
Error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
May 31, 2008 | Sharp AR-BC260 Color Copier
Sharp MX-2300N Color Copier Logo
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
