Question about Team International Hawk Talon V3 RC Indoor Helicopter
Propel rc speedstar will not sync with remote
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
SYMA RC CENTURY BOAT DOESN'T WORK OUTSIDE WATER
Actually the Syma Brand Boats are designed to not to work out of water. It is a safety feature. You can bypass that if you like. You remove each wire that is soldered to each propeller shaft and twist them together.
Apr 10, 2014 | SYMA Toys industrial 30" RC SYMA Century...
Speedstar a200
try here
http://download.cnet.com/1772-20_4-0.html?query=diamond+speedstar&platform=Windows%2CMac%2CiOS%2CAndroid%2CWebware%2CMobile&searchtype=downloads
Feb 26, 2014 | Rio Diamond SpeedStar A200 (8 MB) Graphic...
Cant program olevia rc-ltl remote control to sony vcr
This remote control cannot be set in sync; with Sony VCR, as it does not have a setup code.
Mar 30, 2013 | Olevia RC-LTL Remote Control
Rc sunfire. remote works the steering but not the throttle.
try sync it to level 4 on it will turn green on full throtal I did it then I had to do it again because I charged the battery and had to sync it again try this when I did not do it second time it just stop tell me if that is the problem not a good discharge battery for 3000ninh 8.4
Sep 04, 2011 | Exceed-RC Exceed RC Brushless Pro SunFire
Hello, i have problem with flying back and forvard, becouse rear propeller does not work. What is wrong and can i fix it? Thanks :)
Yes if the rear propeller does not work the helicopter cannot be made to turn around. So it is important that the rear rotor works.
Now make sure that the drive is working to let the motor work , if controlled by the remote make sure the remote command works or is a fault in the remote.
Check the mechanics of the rotor movement. reset.
Dec 31, 2010 | JCPenney Gyropter RC Helicopter
MY CESSNA IS NOT TAKING OFF. IT ALWAYS GOES TO HIT THE GROUND, I SPENT A LOT OF MONEY AND NERVER SUCCEDED WHEN TRY TO FLY. COULD IT BE A PROPELLER PROBLEM?
Check the flight controls. Does the elevator works? if it does. then problem is on thrust. check the propeller speed, does it have enough power? Don't forget to check on the powerplant (battery or engine). But judging from your story, it is the flight control problem. cheers.
Oct 24, 2010 | RC Cessna 747 Airplane 4 Channel Electric...
Team International Hawk Talon V3 RC Indoor Helicopter Logo
54 people viewed this question
Top Team International Toys Experts
ray gallant
Are you a Team International Toy Expert? Answer questions, earn points and help others
