Question about Craftsman Sears Table Saw Manual Model 137.218020
Blue sparks blowing out of motor of new craftsman table saw
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 4 Answers
SOURCE: I have a Craftsman table saw with a burned out
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Posted on Apr 15, 2009
  • 187 Answers
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
Posted on May 08, 2009
protek480
  • 1714 Answers
SOURCE: Table Saw Craftsman 113.299410 Manual
Here ya go...
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0060111.pdf
Posted on Sep 22, 2009
SOURCE: Wiring diagram for a Sears Craftsman 110/220V motor
I found a local small motor technician who was able to help with the wiring configuration for the 110/220: I had wanted the motor to run on 110V
Posted on Dec 04, 2009
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
My 10 in. Craftsman table saw is blowing the house circuit breaker
If it was the bearings you would probably hear a change in the sound of the saw before a significant amount of drag would cause this problem. If you are using the same outlet and the same cords as when you did not have this problem, then something has deteriorated. Is the blade sharp? Has the cord become compromised - either the wire itself or the plug? (The stranded wire in the cord could be hanging on by a few remaining strands.) Does the plug fit nice and tight in the outlet? Perhaps the motor has overheated and has partially shorted out some of the windings. On the other hand, if you have changed extension cords, perhaps the cord is too light or long.
Jul 09, 2012 | Craftsman 10" Table Saw
My craftsman table saw will not run.
That is the selinoid..it needs replaced..if it is not under warranty ...buying a new motor from Harbor Freight would be best ..I did this my self this year..Craftsman could not replace the selinoid on mine so that was my fix
May 24, 2012 | Craftsman Table Saw
On a Craftsman 10" table saw Model 137.221960,
I have this saw. Motor just went on me (siezing up and smoking/burning) so if anyone can use parts then you're welcome to them. jmbombadil@yahoo.com in Conshohocken, PA.
Sep 20, 2011 | Craftsman 10" Table Saw
I own a 10" craftsman tablesaw (model #
Wait for the motor to cool then try again..... you may use compress air to blow across the motor to speed the process.
Jan 19, 2011 | Craftsman 10" Table Saw
Table Saw stops and won't restart
On some motors they are not sealed saw dust gets in the motor and can cause them to overheat they have a themal coupler built in the motor it is being tripped .On sears you can got to sears replacement parts and get a new coupler.If you are not familiar with electric motors.Please take the motor off unplugged!!! mark the ends and caps with a mark or line so you can line them back up on either end .Remove the covers on the ends clean out the motor if full of stuff blow out or use a can of electric motor cleaner available auto parts stores clean all parts find the coupler go to craftsman parts they have a parts diagram online so you can identify it replace it try again if it still does it replace the motor or the saw.
Nov 11, 2009 | Craftsman 10" Table Saw
I have recently replaced my 29 year old craftsman 10" table saw with a new switch. In trying to turn it on, the motor hummed, slightly oscilated and tripped out the wall breaker. I checked the Sears parts...
You may find a replacement motor on ebay. I deal in Craftsman Belt drive table saws, yours looks to be a direct drive. Sorry I wouldn't be much help with those, Jim
Oct 21, 2009 | Craftsman 10" Table Saw
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
Apr 16, 2009 | Craftsman 10" Table Saw
Craftsman Sears Table Saw Manual Model 137.218020 Logo
22 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
