Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE5T error code rl
During cleaning cycle machine stopped at about three minutes into cycle. code looks like rl
  • 125 Answers
SOURCE: kenmore elite oasis he top loader
Is it an f code followed by a 51?
Posted on Jan 21, 2008
  • 135 Answers
SOURCE: ld error code on kenmore oasis
ld stands for long drain. If you can remove the bottom panel you will see the pump in the middle front which has a clean out you can unscrew. There is usually obstructions in the clean out such as a sock causing the long drain. When u remove the clean out cover alot of water will come out so a wet vac comes in handy.
Posted on Apr 15, 2008
IFIXALL
  • 868 Answers
SOURCE: Kenmore Oasis HE 2708..LF error code
Replace the water valve
Posted on May 26, 2008
  • 17 Answers
SOURCE: Kenmore he2+Will not go through clean machine cycle
Open bottom panel, there should be a tech manual, see what the error message means.
Posted on Mar 07, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have been trying to run the clean cycle on my
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
Kenmore Elite HE5t Washer stops in the middle of cycle with no error codes. Any idea how to fix?
sounds like the door switch either needs adjusted or totally replaced .try leaning against .next time instead of opening it
Aug 24, 2015 | Kenmore Elite HE5t Washer
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I can't find my users manual and I am getting an rL code on my Kenmore he5t front load washer.. Can you tell me what that means please?
"rL" indicates garments were detected (by weight) inside the wash tub during a Cleaning Cycle. Anytime the cleaning cycle is selected, the wash tub must be empty. Press PAUSE/CANCEL and inspect the wash tub and rubber seal (bellow) for any loose garments. If the error reappears, try unplugging the washer for at least 30 minutes to reset the Central Control Unit (CCU). Sometimes, resetting the CCu can clear momentary program glitches. If the error reappears following a CCU reset, you may have a legitimate issue.
NOTE: EACH ONE OF THESE APPLIANCES COME WITH A TECHNICAL DATA SHEET INSIDE. THIS IS THE SAME SHEET AN APPLIANCE REPAIRMAN WILL REFERENCE ON A SERVICE CALL. REFER TO THE TECH SHEET FOR MORE DETAILED TROUBLESHOOTING INFORMATION.
The tech sheet contains troubleshooting data, wiring diagrams, diagnostics procedures, component illustrations and all error code definitions.
To access, you will need to remove the lower toe panel directly below the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access to the screws (a 2x4 works well for this). With the screws removed, the panel should drop down, and come off. If the tech sheet isn't directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
It is recommended that the tech sheet be placed back inside the appliance when repairs are completed in order avoid losing and to keep this pertinent info for future use. If you have any questions, please post back and let me know. I hope this helps you.
May 09, 2011 | Kenmore Elite HE5t Washer
I was running the clean cycle on my Kenmore front loading washer and it keeps stopping and reading rL. It wasnt having any probs working on reg cycles, only when I was trying to run the clean cycle. What...
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions.
The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub.
Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!
Sep 15, 2010 | Kenmore HE2 Plus Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
My empty washer keeps giving me an rl error while trying to run cleaning cycle
Sep 26, 2009 | Kenmore Elite HE5t Washer
Error code RL keeps occuring when washer is in CLEANER MODE
rl code is load detected in drum during cleaning washer cycle. Book answer is to remove clothes and start the cycle again. Here's everything that Whirpool doesn't want you to know or do to your machine. Don't blame me if you do anything that damages your product. This is a link to the on-line 'technician' only service manual for your washer.
http://www.scribd.com/doc/7075573/Whirlpool-Kenmore-HE2-Plus-Troubleshooting-Tech-Sheet-8540259
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load washer problem
rl means there are clothes in washer during cleaning cycle...however .there is a glitch in the program and have seen that rl code with no clothes in washer...don't bother calling repairman it's a program issue with the computer last i heard there was no fix forthcoming and customer were to be told to use normal cycle as they would the clean cycle
Sep 06, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
