Question about Winegard Sensar Pro TV Signal Meter
All the yelow flashing lights - Winegard Sensar Pro TV Signal Meter
Catridge wount move to the center to refille and the yelow light blinking
Hi there :you should check for any obstruction on Carriage ( where the cartdridges are on the move) , try help moving it ( not force it ) .About the yelow light that is the cartdridge is Over or not being reconized .Is it a Canon Original or refilled ?Canon original cartdridge have a chip that Keeps the information when the cartdridge was empty , so a refilled one may not work .I hope this information helps you.
Dec 13, 2011 | Canon Office Equipment & Supplies
YELOW LIGHT FLASHING WILL NOT COME ON
You have not mentioned the details of the make and model . This is a power related issue within and is due to a error protection within that has switched the +B. If this is a CRT type then the flyback transformer /driver is damaged and must be replaced hoping that there is horizontal drive to the circuit.
Sep 30, 2011 | Computers & Internet
I replaced the lamp now the lamp light on the frount of tv flashes yelow and tv does not turn on
The flashing yellow lamp light is indicating that the lamp door cover isn't installed properly or isn't contacting the door switch .
Aug 12, 2011 | Mitsubishi Televison & Video
Brake light changed for audi a4 2001 but in warning light Problem
if hand brake indicate and flashing . means brake fluid need fil up on level . if heater light ( yelow)still falashing after replace brake light S.w check injection pump . in case if you vehicle still runing you can remove two line fuel and try feed with injector clean for few mint until water drain out from injection pump .
Jul 07, 2011 | Audi A4 Cars & Trucks
When i turn my ofice jet 4110 on, rhe yelow light comes on for approximately -3 seconds and is immediately replaced by the flashing red light which stays on no mattr what i try.
There are usually 2 culprits for this. Try these first and they might solve your problem.
1. ink cartridge jam - sometimes the ink cartridge is loose. just remove it and put it back.
2. paper jam (or other stuff) - sometimes some paper/paper clip/ rubber band gets jammed in the paper feed
Try also looking at the PC/laptop which it is connected to. There is a chance that a message will show the actual printer problem.
May 18, 2011 | HP Officejet 4110 All-In-One InkJet...
Wen I push it a little more then normaly, de yelow motorlamp goes on. ist happand on about 150 km/h. and 3000 rpm.
If the light goes on and keeps flashing, then it's detecting a misfire in your engine. If the light goes on and stays solid, then it could be anything. If you take your car to a place like Autozone(free) and have it scanned, they'll be able to retrieve the codes that will narrow down what the issue is
Sep 15, 2009 | 1998 Volvo S70
New controller not charging
haha those flash becase interntet is accessing i think r whetere hard disk is accessed at all sotat has nothing to do wiht it .
May 19, 2009 | Sony Playstation 3 (PS3) Console
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Solid yelow led and the red led is flashing
Check your manual or:
http://www.toshiba.ca/web/pdf/5056HM66_EN.p.pdf
Use the quick restart procedure
Jun 13, 2008 | Toshiba 50HM66 52" Television
Winegard Sensar Pro TV Signal Meter Logo
51 people viewed this question
Top Winegard Televison & Video Experts
Electro Med Services...
Are you a Winegard Televison and Video Expert? Answer questions, earn points and help others
