Question about dr. Tech Solar Transmitter Wireless Weather Station WA-1070T
THE WIND GAGE QUIT WORKING
WIND SPEED WORKED FOR ABOUT TWO WEEKS THEN QUIT WORKING
Gages on dash quit working
if they work when not driving ,then its not a fuse.
what is gages,my englich is not so good.
Mar 09, 2014 | 2004 Ford Taurus
I have a 2001 toyota tacoma v6 4x4 the speedometer quit working so I replaced the speed sensor and it still isn't working any ideas
-Make sure you hook up right.
-After connect to the meter gage, you need to turn from under neat
to make sure it turn before connect at transmission.
-remove it and double check again.
Good Luck
Mai
Nov 12, 2013 | Cars & Trucks
The light in my dash that alluminates my MPH gage is out this is after my cigarette lighter port quit working earlier in the week
Check your fuses, most likely one or more are blown. Change the blown fuses with the same size and watt fuse.
Jan 15, 2011 | Saturn SL Cars & Trucks
Speedometer quit working on 2001 voyager all the other gages are working
Check the speed sensor located at the tranny or in some cars at the left wheel shaft. I don't know where your particular car has the sensor.
Dec 09, 2009 | 2001 Chrysler Voyager
I have a 1996 Jeep Cherokee Classic. My Tachometer, Fuel Gage, and Speedometer quit working a few months ago. The Oil pressure,and Temperature gages work fine. All fuses are fine. I suspect a grounging...
have you tried working on one problem at a time?
have you check the body computer for any codes?
and to also verify the bus line is ok.
if you find nothing wrong with BCM or bus,
try checking the speed sensor for an output signal or if the gear is bad.
Nov 18, 2009 | 1996 Jeep Cherokee Country
Everything on dash quit working speed olm,fuel gage ect . is not a fuse problem
sounds like the green relay in either fuse box or engine compartment has failed m8
Oct 02, 2009 | 2002 Pontiac Sunfire
All gages on dashboard, including turn signals not working
one of the smaller red wire at the battery terminal has a bad conection, you may have to make or replace the battery + cable connection.
Aug 20, 2009 | 2002 Dodge Grand Caravan
1998 Contour Speedometer, gas gage, odometer not working
check the relay for the dash gauges.
Robert
Sep 22, 2008 | 1999 Ford Contour
dr. Tech Solar Transmitter Wireless Weather Station WA-1070T Logo
29 people viewed this question
Top dr. Tech Measuring Tools & Sensors Experts
Lawrence Oravetz
ray gallant
JonSnell Electronic
JonSnell Electronic
Are you a dr. Tech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
