Question about Apple 24" iMac Desktop
How to open imac - Apple 24" iMac Desktop
    Top Expert:
  • Apple Master
  • 14,161 Answers
Posted on Feb 24, 2016
JPEG files won't open on my iMac
Not a great solution but I have been able to get the pictures from this camera to open in Photoshop only. Still have not figured out what is wrong with the JPEG files.
Dec 27, 2014 | Sears Discovery Kids Digital Kids Camera
How do I take apart my imac?
It's for advance users only because you need special screw drivers and previous experience to open an iMac. I have seen alot of time when new users open iMac and broke the lcd connector. So I advise to be very careful as it may cost you more in the end. Thank you and good luck. Tech from
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Sep 06, 2014 | Apple 24" iMac Desktop
Change HD to imac 24
Tricky. The glass screen panel held in place with magnets believe it or not. Here's a step-by-step. http://www.ifixit.com/Guide/iMac+Intel+24-Inch+EMC+2134+and+2211+Hard+Drive+Replacement/8968/1
Oct 03, 2012 | Apple 24" iMac Desktop
Imac g4 won't start but shuts down when apple logo appears on screen
Are you sure the iMac is really shutting down or just turning off the backlight? The tell-tale sing would be to let the unit fully boot-up (wait 3 minutes) and the press the button the apple keyboard that ejects the CD-ROM. If the CD-ROM door opens, you iMac is running with disabled or broken backlight.
The inverter circuit on the iMac G4 is known to be weak.
There could be another problem, though. The iMac G4 is also known to have weak internal power supplies. Here's how you can tell:
Hold down the CMD OPT "O" and "F" keys at the same time while pressing the power button. This will tell the iMac that you want to boot into the Open Firmware shell, bypassing the Mac OS X startup. If this works, your power supply is good, the inverter is good and you have a problem with your Open Firmware boot string. To fix the boot string, Power on the unit while holding down the keys CMD-OPT-P-R to zap the parameter RAM (PRAM) and reset everything to defaults.
If you were not able to boot into the Open Firmware shell, your problem is either a failed power supply or a failed screen backlight. The last possible culprit is your iMac could suffer from "Bulging Capacitor Syndrome", where a batch of iMac G4s, iMac G5s another electronics were fitted with a bad batch of capacitors. Eventually, the caps will rupture and cause irreparable damage to the logic board. Only way to verify this is to pull the unit apart and visually inspect. If you see little green or blue cylinders that seem to be bulging or oozing a thick oily goo, that's your problem. Only recourse is to shop around on eBay and look for a replacement logic board.
May 30, 2010 | Apple iMac G4 Desktop
How to replace power supply Imac duel core intel flat pannel
You need a Access card to open the Imac from the back side and then you have to open LCD and under the LCD you can see the power supply.U need special tools for that.Dont try by your own.take it to a service center
Apr 10, 2010 | Apple iMac Z0CY Desktop
How do I open a iMac a1207
place the screen face down on a cloth Go to where the speaker is located and you will see 3 ot 4 screws depending on the model remove those screws and lift the case by the stand and then you can see where the hard drive is located.
Mar 07, 2010 | Apple iMac Z0CY Desktop
Blueberry iMac with slot-loading CD rom drive will
It would be very difficult to open up the imac to retrieve the disc as the CD drive is totally enclosed and would probably result in it not be functional after removing the disk. Have a look at the following article on the apple website
http://support.apple.com/kb/HT3007?viewlocale=en_US as it does indicate that the slot loading imac does have a hole for paperclip ejection. You could also try opening up disk utility and and clicking on the icon of your disk under the left hand column then go up to eject button and click eject. Hope this helps.
Nov 12, 2009 | Apple iMac G3, G4 USB Keyboard 9224078
Imac g4 dead
Hello, The power supply is part of the motherboard in the iMac G4, so it's hard to change it. The repair would certainly cost more than the price of your iMac. You can try to take off the small battery, and reboot it to see if it changes. To open the mac lay it down, screen on the table (on a t-shirt). Unscrew the four screws (they wont come out, so just unscrew them. Pull the screws and take off the silver plate. Then you'll have access to the inside. Good luck
Jun 12, 2009 | Apple iMac G4 Desktop
G4 imac CD tray keeps opening
You may be trying to load a corrupted disk, or your mac may have a faulty mother board. sorry, im not quite sure exactly what your problem is, but good luck anyway...
Mar 08, 2009 | Apple iMac G5 Desktop
Apple 24" iMac Desktop Logo
285 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
