Question about Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360
How to calibrate xbox controller - Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360
My controller keeps making me head backwards
Sounds like a calibration issue. It can also be a hardware problem in which case you will be better off buying a new controller. You haven't clearly mentioned exactly what brand your controller is. Is it Logitech or Microsoft brand? It is for PC or XBOX?
If its Microsoft brand and for PC you can try calibrating it from Control Panel -> Game Controllers -> XNA Gamepad -> Properties -> Settings -> Calibrate.
Nov 16, 2012 | Microsoft Logitech Wireless Black...
Calibrate xbox 360
Hi calibrate the console or the controller?
Apr 07, 2012 | Microsoft Xbox 360 Console
Wireless controller calibration
Press the round button that is next to Memory Slot B on the Xbox 360. Then press the round button next to the LB button on your controller.
Aug 16, 2011 | Microsoft Xbox 360 Wireless Controller
Xbox 360 game contoller keeps disconnecting and wont reconnect.
You can try switching out new batteries, both the console and controller off and trying to turn one on and then the other and then try a different order of turning them on if that doesn't work, and if that doesn't work then try (after restarting the console and with the controller initially off) using the calibration button on the console and then holding the calibration button on the controller. If that doesn't work, call xbox support.
Mar 01, 2011 | Microsoft Xbox 360 Console
How to set up tony hawk shred board. on the tv it says to connect the board, and the light on the board keeps blinking green
You need to connect the board to the XBOX before you can calibrate...press the Connect button on the main console (on my XBOX 360S it is directly to the left of port 1 for the game controller), then press and hold the tiny button far left on the board controller. That's as far as I got, it won't calibrate to save my life!
Dec 26, 2010 | Activision Tony Hawk: Shred
My xbox 360 elite is randomly disconnecting itself from both of my controllers and the batteries are brand new and fully charged
Hello
If you replaced the batteries then you may need to re calibrate the controllers to the x box console.
Dec 14, 2010 | Microsoft Xbox 360 Console
Why wont my xbox tony hawk bord callobrate
  • Return to the main menu and select "Options", then select "Calibrate Board" and follow the onscreen instructions. Make sure to follow the steps exactly and hold the board in the calibrating
  • Nov 20, 2010 | Microsoft Xbox 360 Wireless Controller
    The guitar wont sync with the xbox
    Try calibrating your controller, if that doesnt work more than likely your controllers "picking" button has worn, it's happen before. Ex) you click on a note right when it comes, but it delays, or it won't do anything. If this is true, buy a new guitar controller.
    Good Luck!
    Jan 01, 2010 | Activision Guitar Hero III: Legends of...
    Cannot get the skateboard controller to calibrate on tony hawk ride xbox360
    hey i cant get my board calibrated for some reason i keeps coming up as try again
    Dec 25, 2009 | Microsoft Xbox 360 Wireless Controller
    How do sync the guitar w/ xbox 360 console?
    Start the game and go into the options menu. There is an option to calibrate lag. Complete the instructions and the guitar will be synchronised with your TV.
    If you mean how do you assign a guitar controller to the console, press the small button near the headphone port after pressing the guide button to turn the controller on, then press the small circuar button on the front of the console like you would with a regular 360 controller to assign the controller to the Xbox.
    Jan 24, 2009 | Activision Guitar Hero III: Legends of...
    Activision Cabela's Dangerous Hunts 2011 with gun for Xbox 360 Logo
    Top Activision Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    James Wishart
    ray gallant
    Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
