Question about Yamaha CDC-901 5-Disc CD Changer
Cd player door sticks have to push it to close and will not program for randomplay
How can i open my cd drive to insert my cd?
If the button on the drive won't pop open the drive, then you need to find out what is causing it to stick closed. Most drives have a tiny hole on the door so you can push a paper clip in it to open the door.
Jun 17, 2015 | Computers & Internet
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
I have a Sharper Image Blue Night CD Player with a motorized CD cover that automatically slides up or down (to play CD) at the touch of a button. When I push the button to close the door (and play CD),...
I would first check to see if there is something that is obstructing the door, and if you cannot find anything, then you could take it to any electrical repair shop, and they could fix it for you.
Mar 26, 2011 | Audio Players & Recorders
I own a Philips CD 950 player. I now cannot open or close the CD compartment. How do I remove my disc? I live in Manhattan, New York City and wonder if there is a service center near me.
The small gear that opens or closes the door goes bad after 10 or 15 years. The gear is not available separately. The solution is easy. Take the deck cover off with a torx bit, and remove the broken gear pieces. Push the CD transport door out, and fasten heavy clear mailing tape on both top and bottom of the center of the CD transport door to make a Grab Tab you can use to pull the door open. When you load the CD you are going to hear, push the door open/close switch twice to fool the deck to go into PLAY mode. Mine has worked great like this for 6 years now, and it still sounds beautiful.
Oct 03, 2010 | Philips Audio Players & Recorders
Cd draw in slot a will no come out
stick a straight pin or small paper clip in hole just below drawer and push to trip manual door release
Nov 05, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
The cd door hangs and won't open without assistance
the belt may be streched so you may need to get a new belt.
Jul 02, 2009 | Yamaha CDC-565 5-Disc CD Changer
Cd tray not staying closed
gently push the cd door back in while pushing the door closed button , untill it closes if it still comes out then the cd laser mechanism is not lifting or something else has happened , then it will need to be tested to determine the exact cause
Oct 16, 2008 | Memorex MKS5001 Shelf System
Numark Cd-Mix-2 left side disk problem
Cd drawer and laser assembly are belt driven. Belt needs to be replaced
Sep 08, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
Yamaha CDC-901 5-Disc CD Changer Logo
27 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
