Question about Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum
How do you remove the Handle from the Hoover Windtunnel Deluxe to replace the switch?
The switch on my Hoover Windtunnel Deluxe no longer works.  I know it can be replaced very easily by removing the handle but I cannot get the handle to to come off.  I removed the 2 screws in the back of the handle but the handle does not easily slide off.  What step am I missing?
  • chomaha Jan 06, 2008
    My on/off switch does not work, and the machine is smoking (like it is burning) I removed the bottum plate to see if the belt needed to be replaced, but it seems fine.
  • 4 Answers
Removing the handle assembly should be easy after removal of the two screws. It may be binding or hanging up on the self-propel cable...or the plastic may just be stuck/binding. Note that the handle slides in and out of the vacuum unit along the same axis as the two screws (i.e. slides straight off the back towards you when you are standing behind the vacuum). Try to pry it off gently w/thin-bladed screwdriver or butter knife (careful now!). Not sure about the smoking issue but you may have a severely plugged filter and the unit is overheating as a result. Check that out immediately/first to avoid fire or expensive motor burnout.
Posted on Jan 02, 2009
After removing the two screws on the back of the handle, a good whack on the handle from front to back with the palm of your hand or a rubber mallet will knock it loose.
Posted on Oct 01, 2011
Remove screw on front above switch and pull up
Posted on Dec 11, 2007
SOURCE:
Replace on off switch on u5458-900 hoover vaccum cleaner
Remove the screws that hold the upper handle assembly onto the body of the vacuum. The upper handle assembly will slide off the back to reveal the power switch
Dec 28, 2013 | Hoover U6616-900 WindTunnel Bagless...
How to remove the hoover windtunnel handle release lever
Tilt the handle back and pry it out with a flat blade screwdriver.
Jan 23, 2013 | Hoover U6630-900 WindTunnel Bagless...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
I just bought a Hoover Windtunnel upright with bag, #U6485100. When installing the handle there was tape over the top with instructions do no remove until assembled. After assembling (screwing in the...
Be sure the on/off button and the power drive button are both in the OFF position before installing the handle. The actual switch inside must also be in the OFF position.
Feb 27, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover windtunnel, model U5470900. The on-off switch is broken. How do I order the parts and what is the instructions for replacing the switch?
I think this is a common problem, as the actual switch is located behind the cleaning tools caddy. The switch is toggled via a long, plastic rod connected to the thumb slider on the handle. It's a comically poor design. I'm not sure, but I think you'd have to replace the entire handle assembly if the slider no longer works. An easier solution is to simply plug the vacuum into a surge protector with an on/off switch.
Feb 13, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
The power button quit working
Please click here to see the part diagram for the Hoover Windtunnel Self Propelled model U6446-900
Greetings from GoVacuum,
For replacing the switch, you need to remove the 2 screws that are in the back of the vacuum where the handle connects to the vacuum bag housing, Part # 50 on the first page of the diagram. After the screws have been removed, you may simply slide out the handle from the rest of the vacuum cleaner. You can then at this point view the outside of the switch, however as you'll find you can't replace it from this side. You'll then need to go into the where the tool caddy is in the front top part of the vacuum cleaner. Remove the attachments from the tool caddy, and then you'll need to remove the screws that hold the tool casing in place. Remove screws pictured # 35 on page 1, and the tool caddy is item # 17.
Once the screws and the tool caddy are removed, you may then see the rest of the switch, and the leads that connect to it. The easiest way to remove the screw is to use a flat head screwdriver and pry the switch out from the back of the vacuum cleaner after removing the leads from the switch. The new switch that you'll need to purchase is Hoover part number 28161067 which can be found online here: Hoover Windtunnel Main On / Off Switch Part Number 28161067.
I hope that this helps you replace the faulty switch in yours (and your parents) vacuum cleaners. If you need to place an order for the switch, please give us a call at 1-866-468-2288.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6446-900 WindTunnel Bagged Upright...
Hoover Windtunnel
Take the handle off, then remove the tool holder, then you can get to the switch. Just has tabs on each side of switch, depress them and push it out. These switches will do this after awhile, replacing them is usually the way to correct the problem.
Dec 29, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
U6439-900 will not turn off by the level in the handle.
These switches go bad, best to just replace it. Could have a problem with the rod inside the handle.
Apr 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Dec 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover U5450-900 Windtunnel Supreme Bagged Upright Vacuum Logo
1,565 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
