Question about Cell Phones
Tracfone lg320g My phone will not charge even when I put the charger in. It keeps blinking out of battery!! What should I do?
5 Suggested Answers
  • 61 Answers
SOURCE: my tracfone will not come on,only the lights
You'll wanna ensure your phone is totally charged. Also, let it completely drain before putting back on the charger. This will help with the charging memory.
As for the phone. Do a master reset: to do a "Master Reset". I went to "Settings," "Other Settings," "Initial Setup," "Master Reset" and put in the security code. "1234" is the security code if you have not reset yours.
It'll get the phone back to as you got out of the box, day one! Your numbers will be fine. You'll notice the ringtone and the wall paper will be the orignals.
I know this will work!
Cheers!
Posted on Feb 04, 2009
SOURCE: my tracfone wont charge at all!
ok u need to buy a new battery
Posted on Jul 23, 2009
SOURCE: wireless phone wont stay charged..loses battery
Repace battery in LG cell phone with a Ray vac batt and go down
while not using phone
Posted on Apr 24, 2010
Geekman
  • 32281 Answers
SOURCE: I need the Pin code and the PUK code to my LG320G
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
Posted on Mar 10, 2011
How do you know when the battery is fully charged?
make sure the charger cable is working or try a different one
Sep 29, 2014 | Tracfone Wireless Alcatel A392G
Lg800g
Mine keeps doing the same thing but so far I can get it working again by pulling the battery out and putting it back in. Sometimes I have to do this several times. It also helps to plug it into the charger and get a full charge on it. I`m buying a different phone though because I don`t know how long this will work.
May 13, 2014 | tracfone.com
Phone wont hold charge keep cutting off
Hello, either your charger isn;t working or your battery is bad, replace or take in for repair.
Mar 04, 2014 | tracfone.com
My Motorola CLS1110 Two way radio has issues charging. I have a 6 station charging station and when I put the walkie on the dock to charge the light just contiues to blink red. I have to continually...
You may have a bad battery, or even dirty battery contacts. A few troubleshooting ideas include:
1) Swap the battery to another known good CLS1110 radio and see if the other radio has the same problem when placed on the charger. If so, you have a bad battery. This type of battery typically lasts approx. 18-24 months before needing replaced.
2) If swapping the battery proves to be successful, check the battery contacts on the affected radio for debris, scum or dirt. Clean the contacts on the charger and the radio with a pencil eraser if needed. (The fact you have to readjust the walkie in the charger indicates you might have problems with the contacts.)
3) Try the battery from the known good radio in the affected radio, if the battery charges correctly, you know the radio is fine. If the charger blinks with the known good battery, then you know you have a radio problem.
Best regards.
Nov 10, 2010 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Phone not turning on keep beeping red light. phone make. sony ericsson w580i
Your battery is probably out of charge.... Try charging it.... If the red light keeps on blinking even after charging it for a sufficiently long time You will either need to
1. Change your Battery.
2. Perhaps change your charger.or get your charging port checked and repaired.
Nov 04, 2010 | Sony Ericsson w580i Cellular Phone
Tracfone will not charge
try dismantling the phone, keep it disassembled for sumtime... assemble again.. try recharging..
if it still doesnt work, have your charging port checked with an electronics mechanics..
Dec 11, 2009 | Nokia 1100
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
My tracfone will not come on,only the lights
Cheers!
Feb 04, 2009 | Motorola Mobility TracFone C139-4 Cellular...
My MDA won't turn on even when its on the charger.
THE SCREEN AND LIGHTS HAVE BLOWN YOU NEED NEW PHONE
Apr 11, 2007 | T-Mobile MDA
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
