Question about Sony RDR-GX300 DVD Recorder
Sony rdr hdc 300 turns itself off a few seconds after you turn it on
The unit is 3 years old. When you turn it on, it turns itself off within a few second. The only thing it allows you to do is change channels, however, when it turns itself off, it does not remember the new channel. I cannot access any other menus, eg system menu, guide, timer, etc. I have used the resent button several times to reboot, but it has not solved the problem. thanks
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my sony DVD RDR-HDC, program guide is really poor and only gives maybe 2 channels of programs. How do I update the system so all the channels show the programs Thanks
get the support from sony. go to www.support.sony.com
God bless you
Posted on Oct 01, 2012
How do I unlock my dvd HDC 300 recorder?? The door does not open and says Locked
If you have the manual it should say something about a child lock
Oct 20, 2014 | Sony RDR-GX300 DVD Recorder
My 4 year old Sony RDR gx 300 burns fine on old Memorex , Fuji DVD R s but bought some new DVDs by memorex and Maxell and both won't formatt . It gives the message that disk is dirty or disk error ....
The laser on your drive is probably beginning to go out of alignment.
A plastic grub screw holds the laser carriage at the correct angle on the slider rods. Over time, this screw will get worn down and the laser carriage will begin to lean too far over to one side. This grub screw will need to be tightened slightly to bring the carriage back to the correct angle. I suggest turning it a quarter of a turn (clockwise) and testing it. Repeat a few times until it works correctly.
Sep 30, 2010 | Sony RDR-GX300 DVD Recorder
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
New Sony DVDVCR RDR-VX560 seems to be locked up
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Jun 22, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Turns off and on sporatically
Which model is it ?
On the Go 300/500 series there's a reset in the base. You will need a thin pin or similar to reset.
Take out the map card then turn the unit on.Push the pin into the reset hole at the base.
You will then get the start screen and the maps will reload once you replace the memory card.
On the 7 series, simply hold the on button down for approx 15 seconds until the start screen begins to show.
Apr 29, 2009 | Tomtom GO GPS Receiver
Microwave turns off after 1-2 seconds
It turned out to be the three door attachments that weren't lined up. It has been fixed. We almost bought a new one because Samsung referred us to a service that would have charged way too much to be worth it even thought the machine is only 3 or so years old. Luckily, we looked further. A local independent appliance fixer came to the house and took care of it within a few hours of my call! Yea!
May 29, 2008 | Samsung SMH7174BC Microwave Oven
SONY DVD RDR-GX315
Turn off recorder. Hold the on/off button on the dvd player for a few seconds. until "CHILD LOCK" disappears. The child lock is now disengaged...Check page 37 in the manual (I found it online -- same thing happened to my player -- I just freed it)
www.manualshark.org/manualshark/files/4/pdf_6908.pdf
Jan 04, 2008 | Sony RDR-GX315 DVD Recorder
Sony cd car radio
if you got the radio password or radio code..try to reconnect the battery of your car..turn on your radio,then enter the radio code you hav...:)
Oct 30, 2007 | Sony CDX-M610 CD Player
Childblock
Easy fix; worked for me.
Jun 14, 2007 | Sony RDR-GX315 DVD Recorder
Sony RDR-GX300 DVD Recorder Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
