Question about Kohler Home
Can't remove face plate of tub drain overflow Kohler K-7163
Removed one screw and pulled but face plate won't budge
co7196
  • 3433 Answers
SOURCE: Hello- I'm trying to remove my moen push pull
to loosen a stubborn screw, tap the screw driver wit a hammer lightly while tryng to turn.
Posted on Jun 10, 2009
  • 297 Answers
SOURCE: Slow water drain from Royal whirlpool tub. How to
under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
Posted on Jul 30, 2009
  • 82 Answers
SOURCE: My 2000 kohler tub drain leaks. The drain itself
Need clarification....the drain leaks to the ceiling below, or it doesn't hold water? If it doesn't hold water, no need to replace the ring. Those can be adjusted. Simply pull up on on the lever and screw it in clockwise. This will lower the stop and hold the water. If it actually leaks below, unscrew said stopper, grab a pair of needle nose pliers and place them in the drain (to grab the strainer) and use another pair to loosen. Once off, clean around drain and clean strainer, apply plumbers putty to the strainer, apply pipe "dope" (thread sealant) to the threads and tighten back in. Good luck!
Posted on Nov 27, 2009
SOURCE: pump will not turn off. Have removed tub face.
If the Pump will NOT turn OFF, then the switch, must have failed, in the ON position, I suspect you will need to replace it.
Posted on Apr 28, 2010
SOURCE: How do I remove the
Does the tub have a lever to stop the drain below the spigot ?
Posted on Oct 28, 2010
K-1357 kohler whirlpool tub there is leaking only when the tub is filled and drained. when taking showers there are no leaks 3yrs old
Overflow? Seal around drain may be good enough for shower, but leaks with a little more pressure from the filled tub. Filled tub may flex the tub and drain components. What about the overflow. I bet some water is going over, but it isn't used for showers. Double check. Paper towels tied in stratigic locations always help me find a leak. Leak makes the towel soak up water nearby. It's most wet at the point of leak.
Mar 08, 2015 | Kohler Home
I have a kohler 77809-aa shower tub. The drain is clogged. How do you remove the drain. I see no set screws. But I do see a couple of pins near the top of the drain cap.
If you want to clear your clogged drain you do not need to take the drain cap off. First you need to remove the over flow plate, it's located right below the faucet and has two screws, then you need to hand snake the drain line from there.
May 30, 2012 | Kohler Forte Single-Control Remote Valve...
I have a Kohler Overflow tub with a faceplate covering the screws that would allow me to get to the trip lever...the lever must be stuck "down" because the tub won't drain. How do I take off...
Hey, I think I've got the solution for your situation.
First off, you want to get a caulk remover and apply that on all the caulking between the tub and the faceplate. Let this soak for 20 minutes. Then you will want to take a utility knife to score around the edges of the faceplate between the faceplate and the tub. Be careful not to scratch the tub! When the caulking has been completely cut through all the way around the face plate, take putty knife and pry the faceplate from the side of the tub. Check out the lever, or see if it is just gunk build up on the filter. Either way I hope this helps, and good luck!
May 19, 2011 | Kohler Archer Clearflo 1-1/2in Bath Drain...
I have an american standard tub and it constantly clogs. I used drane-o and it worked for a little bit but I think its the drain in the tub. How Can I tell if thats the problem?
Take screws out of plate on tub over flow and pull up trip lever. sometimes they move and need adjusting . It shoul dhave 2 bolts holding the plate on tub at overflow and work with it to remove trip lever assembly once out run some water down drain to let you know if that is th eproblem then you can adjust on trip lever assembly by moving the little barrel like plug near the handle a little will increase water flow out of tub once you put it back in you can adjust it out it back in with out bolting back turn water on and move lever to see if it drains any better.
They can be tricky but you can do it.
Mar 21, 2010 | American Standard 1583.470.020 Universal...
Drain won't move up or down on kohler whirlpool tub
I gather it is a lever handle drain if so you need to remove the plate and linkage at the overflow to clean up the parts and spray it with WD40 or silicone spray and reinstall
Nov 22, 2009 | Plumbing
Good morning! My Kohler tub drain (original equipment - about 40 years) is beginning to shred itself. It appears to be a K-7145 or related popup drain. I've been pulling the screws out of the overflow and...
I can't really put my finger on the cause, but am quite familar with screws not wating to come out of the overflow.
When you finally do get the screws out, see if you can find suitable replacement stainless steel screws.
Get some "copper rich" antisieze from a plumbing shop or auto supply store and apply a little to the threads when you reinstall them (hopefully new screws).
After 40 years, a new tub drain may also be in order, but depending on the location, that can involve a great deal of work.
Best of luck to you!
Oct 27, 2009 | Kohler Plumbing
I have a price fister BATH faucet set installed on an old bathtub> i would like to remove the knob that actuates the stopper mechanism. it is slightly triangular in shape and it does not seem to be a...
You will have to change out the waste and overflow. This is not a hard job, unscrew drain from tub, remove overflow plate and disconnect from p-trap. Go to local home improvement store and buy a new waste and overflow kit, many to choose from. Reinstall .
Oct 03, 2009 | Geberit Bath Waste and Overflow Tub Drain...
Hi! Can not remove L-shaped linkage from overflow on old Kohler pop-up drain. Is there any way to do so without removing the pipes? Thank you
most times it just pulls off. some times it is secured with a screw check to see if there is a screw.
Jul 23, 2009 | Plumbing
Bathroom tub drain clogged
If you have a popup/ plunger type drain stopper controlled by a lever at the overflow, then, yes, it would be a great idea to remove that. They commonly add to drain problems.
Remove the two screws at the overflow plate (the one with the lever for stopping the water). Be careful that the gasket between the tub and overfow does not fall out when you fully remove the screws. Pull out the stopper assembly. You may have to jiggle it somewhat. Clear your drain some more and run a little water in it. Then replace the stopper assembly, making sure to keep the overflow drain lined up as you screw the plate back in.
You may consider replacing a lever stopper with a "twist and twirl" type.
If you do not have a lever assembly then you may have to use a small hand held snake to clear out the drain
Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Home Logo
37 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
