Question about LG LRE30453ST (Electric) Stainless Steel Range
Error Code F2 - doesn't heat up, broiler doesn't work either
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
Error code f2 broiler comes on by itself and won't shut off
F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit
Mar 01, 2010 | GE Spectra JBP78 Electric Kitchen Range
F2 code
F-2 error for jenn-air means the oven is to hot, it could be the oven temperature sensor is faulty, or the relay board.
Mar 29, 2009 | Jenn-Air WW30430P Stainless Steel Electric...
Oven top element gets SUPER hot without warning
the sensor in your oven is picking up the high heat and posting error message which displays F2 ,at least the sensor is working but lets look at the problem isuspect one of two the first is your control switch needs tested i would say this is the problem and number two the elemant could be on its way out either of these problems are going to need a electrican to fix ,sorry i cant give you a simple answer to your problem.adrian
Jan 24, 2009 | GE Profile JTP18 Electric Single Oven
Broiler won't turn off. Error code F-3
The broiler won't turn off even when you press the "Off/cancel" button? It sounds like the broiler control relay is stuck shut. The F3 code means the oven temperature sensor has failed, this probably happened because the oven got too hot when the broiler was stuck on. There is fail-safe thermal fuse that will blow if the oven gets too hot, so the oven won't melt down but you should leave the unit off so you don't blow the fuse.
To fix the relay, you will have to replace the oven control module. I think this is about $200 and not too hard to replace if you are somewhat handy. The temperature sensor is also serviceable, you can find parts at Appliance Parts Pros on the web. Hopefully you haven't thrown the range out yet, let me know if you need further assistance.
Nov 27, 2008 | Whirlpool RBS305PD Electric Single Oven
F2 error
an f2 code means the oven overheated.it could be a bad relay on the control board. also if you ran a self clean cycle and left the racks in the oven,i've heard it could cause problems with the oven sensor.
and no you shouldn't have to leave the oven door open when you cook.hope it helps
Nov 29, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
F2 error code
Similar problem. When baking over 400 degrees we get the F2 code that can only be reset by cycling the power at the breaker. Replaced the electonics to no avail. I'm thinking its the cooling fan located between the oven and microwave (upper unit) it never comes on which may cause a separate temp switch to generate the F2... but I'm not a pro. :)
Nov 18, 2006 | GE JGRP17 Gas Single Oven
LG LRE30453ST (Electric) Stainless Steel Range Logo
15 people viewed this question
Top LG Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Steven Clarke
Steven Clarke
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
