Question about Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit
Toshiba error code e130 - Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit
E-studio 282 e130 error code
Upper drawer misfeeding (Paper not reaching the
1st transport sensor):
May 12, 2014 | Toshiba Office Equipment & Supplies
BAXI E130 ERROR CODE AND SHUTDOWN
overheat stat or fan check very small hose at fan area for pinhole
Oct 02, 2009 | Water Heaters
I need the manual
It is here;
http://www.sandisk.com/Assets/File/pdf/retail/Sansa_ug_ENG.pdf
Best of Luck.
Nov 16, 2007 | SanDisk Sansa e130 MP3 Player
Sansa e130
ok, for everyone with e130 "keeps getting an I/O device error, only language screen, than something about 4MB memory..." problem, I just spend six hours of my life trying to solve it and fix my dad's e130 and I succeeded ;)
so, step by step, how EXACTLY I did it:
0) my system was windowsXP SP2
1) remove the battery
2) keep holding the menu button and plug in the usb, keep it for a few seconds more, untill the system will tell you it found a stmp3500 and want to install the hardware
3) allow it to reach windows update for that matter and install the drivers
4) now you have new device that is called "Player Recovery Device Class" you can check it in device manager (Right-click My Computer, click Properties, click the Hardware tab, and then click Device Manager)
5) and now is time for flushing new firmware...I managed to find two versions of firmware for e130:
1.0.101e - http://www.sandisk-karty.cz/sandisk-katalog/sansa-e100-series-mp3-players/dokumenty/
2.0.0.01e - http://www.sandisk.com/Retail/Default.aspx?CatID=1295
6) I tried both of them in many different combinations and finally one and one only miraculously worked for me and that was the one when
I HAD THE SD CARD IN THE MP3PLAYER, THE PLAYER WAS RECOGNIZED AS "Player Recovery Device Class" BY THE WINXP AND I STARTED EUROPIAN sansa-2.0.0.01e.exe !
PS: i don't think that there's a big difference between europian and american version of firmware I mention it just to be accurate about the situation. and big thanks to anonymous guy who turned me to right direction with stmp3500. hope that help to others ;]
Oct 26, 2007 | SanDisk Sansa e130 MP3 Player
Trouble using an SD Card
If Sansa e130 or 140 is version 1.x.x.10, SD card MUST be formatted as FAT (FAT16). Music files need to be on the root directory for better performance. I have a SD card (2 gig) formatted as FAT16 and the music plays good.
I was not able to upgrade my e130 to Version 2.0.0.1 Firmware.
Hope this helps
Gary L
txsnowwolf@yahoo.com
Oct 16, 2007 | SanDisk Sansa e130 MP3 Player
San disk e130 mp3
Hi. The E100 series players (including your E130) can only support up to 2GB SD cards.
Apr 21, 2007 | SanDisk Sansa e130 MP3 Player
My sansa e130 dosent wanna turn on, please help
if you find out whats wrong tell me i have the same problem e-mail me at zdittric@telus.ent
Jul 31, 2006 | SanDisk Sansa e130 MP3 Player
Device I/O error cannot access the device message
Got to my computer on your desktop and right click on it. Go to manage select disk management, select your player and then format it. Then reinstall software.
Jun 05, 2006 | SanDisk Sansa e130 MP3 Player
Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit Logo
238 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
