Question about Cameras
My coolpix7600 is flashing battery exhusted even with new batteries what can I do
    Top Expert:
  • Cameras Master
  • 6,702 Answers
Your camera will work with AA batteries.
Always be sure the batteries are charged.
Insert the batteries correct plus to plus and minus to minus. Only one battery the wrong way around and the camera won't work. Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power and can start leaking, causing damage to your camera.
Posted on Feb 16, 2014
New battery In mercedes no power
I'm not a car mechanic, but, it sounds like you might want to check the fuse to the ignition switch, and, if that fails, it might be a problem with the Start Safety Switch on the transmission. Good luck.
May 02, 2017 | Mercedes-Benz S-Class Cars & Trucks
New batteries but wont turn on
Try the following:
1. Ensure the batteries are indeed, charged. Sometimes even new ones are bad.
2. Ensure battery polarity is observed when loading batteries.
3. Make sure the flash ON/OFF switch is not loose or damaged.
4. With the flash mounted on your camera and the power switch to ON, try resetting the camera to factory default settings. This MIGHT clear any errors and allow the flash to work.
Oct 10, 2013 | Canon Speedlite 550EX TTL Flash
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
I bought a second battery (standby as I am going to Africa) for my Inspiron, charged it for about 10 hours until it indicated it is full. However, the power light has been flashing red since. Even when I...
Flashing red indicates that the battery is non-functioning (at the end of its ability to hold a charge), although as it is a new battery, this would seem a bit odd.
Did you buy the battery new or 2nd hand, was it a genuine Dell battery? My suspicions are that if this is an aftermarket battery and one which was not compatible with the dell, then there might have been some damage done to the laptop, causing the old battery not to charge. I'm assuming you are using a genuine Dell charger
Jun 21, 2012 | Dell Inspiron N5030 Notebook PC
My Honeywell Ademco 6160 Alpha Keypad Vista 10E low battery light keeps flashing even after I've change out????
The low battery light will stop flashing when the new battery you just installed become fully charged. It will take some time for the new battery to become fully charged.
Jun 06, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
It says battery is exhusted but the batteries are good what gives
Try cleaning the battery contacts in the camera with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol.
May 19, 2010 | Nikon Coolpix 4600 Digital Camera
Camera shows "exhausted batteries" with new ones.
i have this camera and i had the same problem
everytime i put in new batteries like 5 seconds later the battery was exhusted i tried cheap and expensive batteries but nothing seemed to work
i would recomend rechargealbe batteries because they last longer but if you prefer one-time use batteries you should change they battery type in the menu/ setup
hope this helps!! good luck
Jun 03, 2009 | Nikon COOLPIX L18 Digital Camera
CF-71 battery LED always flashing
hi, first try cleaning all the contacts of the battery and the laptop,let me know
Jan 04, 2008 | Panasonic Toughbook 71 Notebook
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
