Question about Airaid 2001 Ford Expedition - 4.6L V8 - Intake System
Starts then dies - Airaid 2001 Ford Expedition - 4.6L V8 - Intake System
Truck runs fine then dies while driving then will start back up and run ok.
About 56,700 results (0.76 seconds) Search Results
    GMC Sierra 1500 Questions - Truck suddenly stops running ...
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
    1998 1500 5.2 Shuts Off Randomly - CarGurus
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
    GMC Sierra 1500 Questions - started stalling and dying ...
    CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
    Engine Dies and Then Starts Right Back Up
    www.justautorepair.com/chevrolet/blazer/stalls-starts-up
Feb 04, 2016 | 1997 GMC Sierra
Starts and runs fine but when I put it in gear it dies
Riding Mower Dies When Put in Gear ' ThriftyFun
www.thriftyfun.com/Riding-Mower-Dies-When-Put-in-Gear.html
It starts fine, but when I put it in gear to go forward or reverse it dies. It also dies ... The engine on my riding mower will start and run while the clutch is pushed in.
Starts and Runs but Dies When put in gear - YSR 50 ' South Bay Riders
www.southbayriders.com > ... > Community > Maintenance and Repair
Aug 25, 2010 - 15 posts - ‎4 authors
The bike will start and run perfectly fine. However, the moment I put it into gear it dies. ----------------- How we got to this point:...
Engine dies in gear, runs in neutral - Hot Rod Forum : Hotrodders ...
www.hotrodders.com > Tech Help > Engine
Jan 4, 2010 - 12 posts - ‎10 authors
But if I drop it into any gear besides neutral or park, the engine will ... In this case, it shifts fine, and on time, however acceleration is ... start. the engine idling rough and wanting to stall when put in gear is the indicator to me.
Jan 21, 2016 | Garden
Engene dies when is started
It can be issue with fuel pressure,its low or the problem relates to faulty spark plugs.
There are few troubleshooting steps to confirm the problem.I suggest you few help links,with complete troubleshooting and solution for these types of issues.
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm? http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1994 Lexus ES300: Engine Idles Rough and Dies? http://whatisbyme.blogspot.in/2012/05/1994-lexus-es300-engine-idles-rough-and.html
Stalls And Dies At Stop Sign? http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
These help links will help you to troubleshoot and solve the issue.
Thanks.
Oct 21, 2012 | Cars & Trucks
Dies after running about 2 minutes
It's got all the symptoms of a leak in the fuel line. You may want to start backward at the tank and work your way all the way to the carb to find it but it would be surprising if it was something else. All the best.
Greg
Jun 15, 2009 | 1965 Ford Mustang
1989 Bronco starts but dies after a couple of seconds
try checking the thermostat control senser. it caused my bronco to start for a second and then die. after a while it would finally start and run for a while then die driving down the road. i changed the thermostat control senser and it fixed all problems of dieing
Apr 27, 2009 | 1989 Ford Bronco II
92 gmc c2500 turbo diesel. starts then dies after a few seconds.
Sounds like the Pump Mounted Injection Module.. Starts, dies, Starts dies... Not a fun fix.. but atleast it's just under the intake..
Mar 30, 2009 | 1994 GMC Sierra
Airaid 2001 Ford Expedition - 4.6L V8 - Intake System Logo
69 people viewed this question
Top Airaid Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
guymark
Level 1 Expert
Are you an Airaid Wine and Spirit Expert? Answer questions, earn points and help others
