Question about Venta Airwasher VS370 2 Gallon Humidifier
Reset venta vs370 - Venta Airwasher VS370 2 Gallon Humidifier
2 Suggested Answers
  • 124 Answers
SOURCE: I have a Venta VS370 humidifier which works fine
Filters need to be changed regularly depending on environment may have to change more often.
These systems can be very troublesome. It is possible that you are having mineral buildup in your system from the water supply. You can try adding 1/4 cup vinegar to your water to help clean away deposits. See if that helps .
Posted on Mar 08, 2009
How do you fill the venta humidifier I don't have
http://www.appliancefactoryparts.com/content/pdfs/123738.pdf
Fill Water Tank.
Turn off humidifier and unplug the power cord from A/C outlet. Remove tank from
base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled,
filtered, or tap water. Do not attempt to fill unit through Vapor Nozzle. Water temperature
should NEVER be too hot or too cold. Extreme temperatures can damage the
unit. Tighten filling cap firmly. Return tank to base and let it sit for a few minutes. For
first time use or when replacing the demineralization cartridge filter, please soak the
filter in warm water for several minutes.
Dec 24, 2010 | Venta Airwasher VS 207 3.7 Gallon...
Why does my humidifiers does not have any smoke coming out?
My Guess is that the reletive humidity in the room is not low enough to see any vapors coming from the machine. Normaly you won't see these anyway. Some models in the stores seem to make more mist than what you get at home. If the humididty level in a room is close to what is coming out of the machine there will be no signs of any mist coming out. Just make sure the filters are clean and check and make sure the water level is going down on the machine and this will tell you its workin. the faster you are using the water in the tank the more you are putting in the air! If this is a hot mist machine then I would say the heating element in the machine is not working.
Nov 16, 2010 | Venta Airwasher VS370 2 Gallon Humidifier
How often do i need to change the filter?
From the quick research that I did I'm finding 100 hours. That will vary very significantly depending on the mineral content (hardness) of your water. If you have alot of mineral in your water the filter may have to be changed much more often to maintain good operation of the unit.
Nov 15, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Venta 205 no mist
Throw the unit out - it's garbage
Nov 10, 2009 | Venta Airwasher VS 207 3.7 Gallon...
I have a Venta VS370 humidifier which works fine immediately after I change the filter but after a few days the vapour stream diminishes significantly and it ceases to be effective: is this a malfunction?
Mar 08, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Venta Airwasher Display Light Blinking...
This has happened to me. Check the contact points in the base of the machine. Ours had some corrosion on them. I took an emery board and filed the corrosion off to clean the contact points.
Jan 30, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
Can't find the manual online VS207
I have tried looking for a manual for you but I could not find anything after a long search, however here are the contact details for venta, they should be able to send you a manual/guide
Main support number1-888-333-8218
Email supportsales@venta-airwasher.com I hope this helps
Jan 07, 2009 | Venta VS 100 Humidifier
Drum does not turn
The rubber coupling is slipping. You may have a problem with the gear case; you can get a new one by calling Venta at (888) 333 8218. But it's possible that the rubber coupling is simply not seated properly. Snap the gear box out and make sure the socket is clean. When you put it back make sure that the coupling post is fully inserted in the drive socket. Hope this works for you ... Venta will supply new parts promptly if you decide you need them.
Mar 17, 2008 | Venta - Airwasher LW14 Humidifier
Venta Airwasher VS370 2 Gallon Humidifier Logo
46 people viewed this question
Top Venta Humidifiers Experts
Mack Baxter
Dennis
Are you a Venta Humidifier Expert? Answer questions, earn points and help others
