Question about Toshiba 27HL85 Television
Replace capacitor on 27hl85 toshiba - Toshiba 27HL85 Television
Can I get rid of horizontal lines on my TOSHIBA model 27HL85 tv
VERTICAL RETRACE LINES is this problem called technically. Check all the solder terminals at the CRT base card of this TV, for any loose solder terminals.
Mar 10, 2015 | Toshiba Televison & Video
My tv powers up has audio and good lcd display the backlight comes on when u power up the tv not and 2 seconds l8r the light goes out what could be wrong?
Video circuits overheated, shut down ccfl light. Leave tv on standby for a few weeks and it may dry up condensation and work normally. Otherwise you need service.
Dec 18, 2010 | Toshiba 27HL85 Television
No picture only sound
The backlight inverter board may have gone out, or the 24vdc power supply for the inverter board is not working. Check the power supply first since it is easier to get to than the inverter board. Look for burnt parts, bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Toshiba 27HL85 Television
My picture shacks vary fast from side to side toshiba 42H83
You could have a bad color wheel or there is a Factory Service Bulletin from Toshiba that says: Remove the MVUP14 Hyper Module from the TV chassis, remove
the top shield and replace the 10uf, 16v capacitors using Part Number
24619040 as shown in Figure 1. It’s recommended that all of the
capacitors identified in Figure 1 be replaced. (Note: These capacitors are
low impedance surface mounted aluminum electrolytic capacitors. Care
should be taken to avoid damaging the PCB while replacing these
capacitors.) You should call a good TV Tech to do this repair.
Aug 02, 2009 | Toshiba 50H13 50" Rear Projection...
How to change the colors on the tv.
ok idont think theres a code but it should or click menu and go to brightness and you might change it if it dosent work then call the costumer cervise of your tv
May 30, 2009 | Toshiba 27HL85 Television
Capacitors for Toshiba Hyper box
Yes it will take care of numerous problems. Replace all 10mfd caps on the board.
Dec 11, 2008 | Toshiba 57H81 57" Rear Projection...
Bad picturre on toshiba tv
Good Day, pieps57;
Corrective Action: Remove the MVUP13 Hyper Module from the TV chassis, remove the top shield and replace the 10uf, 16v capacitors using Part Number 24619040. It’s recommended that all of the capacitors identified be replaced (Note: These capacitors are low impedance surface mounted aluminum electrolytic capacitors. Care should be taken to avoid damaging the PCB while replacing these capacitors.) CAPS: cx178, cx221, cx230, cx241, cx250, cx261, cx270, cx541, cx670 & c514, c5030.
Good Luck, Big Irish.
Jul 07, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba 27HL85 Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
