Question about Sony KDL-52W5100 TV
Sony Bravia KDL-52W5100 right screen normal, center screen darker than the rest of the screen, left screen blur and movements lag
Right screen is normal, center screen is darker than the rest. The left screen is blur and movements are lagging.
mistersony
  • 320 Answers
SOURCE: Sony Bravia KDL-40V2500
The panel or TCON board has failed, the solution is the same replace the panel. Not worth the cost, get a new TV
Posted on Oct 18, 2008
  • 20 Answers
SOURCE: I have a Sony Bravia KDL-46Z4100 46' I have a green vertical line
this is probly the lcd control module unfortunatley it comes with a new lcd panel
change these.
Posted on Mar 11, 2009
welcomejee
  • 10594 Answers
SOURCE: buzzing/fizzing noise from back of sony flat screen tv
Below is an image of rear side of your TV, Sony KDL-40W5500
Top right corner is marked there and possible cause of noise seems back light inverter board, there are high voltage going to CCFL inside LCD panel and seems high voltage leakage causing that buzzing/ fuzzing noise.
Replace back light inverter board upon voltage leakage confirmation.
Thanks.
Posted on Oct 23, 2009
Testimonial: "Thank you very much for the very prompt reply. This seems a very likely cause. My TV is only a week old so I will contact the supplier. Thanks again."
SOURCE: My Sony BRAVIA KDL-46V3000 Television has messed
This also happened to me and may continue to get worse... If it goes away for a while after warming up, then it is the same problem... The LCD panel is probably going out, when that happens the cost to repair it is more than the tv is worth... If it is in warranty then you can have it replaced or fixed.
Posted on Nov 23, 2009
Testimonial: "You were so right. Thanks."
tvtek
  • 1284 Answers
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
When I turn on my sony KDL-52W5100, its acting like its booting up (showing the sony and bravia)then the screen goes blank. Then the red light start blinking 6 time. what do I do/
Hi
there is a back light problem the connectors of back light are loosing so please go to your nearest Sony service center & solve the problem but if you know about led so remove the o cell & clean the connectors but if you are end user please don't open the led because the panel is thin
Dec 29, 2014 | Sony KDL-52W5100 TV
Sony TV LCD screen blurred down one side when switched on and then after warm up appears to fix itself.
My KDL-52W4100 just started doing the same thing. It blurs down the right side of the screen, then goes back to normal after it warms up. Does anyone know whats up with this?
Mar 24, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Buzzing/fizzing noise from back of sony flat screen tv
Thanks.
Oct 23, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The left side of the screen is kind of blurry and a little darker than the rest of the screen. it gets better after the tv has been on for a while and I turn it off and then back on again, but its not like...
It could be just a cable that feeds the left side of the panel is loose or you have a dry joint on on of the boards inside or one of the boards surrounding the panel is failing.
No simple resolution, you need to contact a Sony service center.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sep 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KDL-52W5100 TV Logo
104 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
