Question about Frigidaire Dryers
Frigidaire FASE7073LW0 dryer smells hot - Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LW0) has an "E64" message listed. What error is this in reference too?
Good Morning Yasmin Abdullah, I am happy to assist you!
Based off the information you have provided your Frigidaire dryer is displaying error code "E64". "E63" typically stands for heater open circuit, which means that it could be a faulty wiring harness or heater. I would suggest performing a reset on your dryer by disconnecting power from it for ten minutes. This could be a false error code or a miscommunication within the board and a reset will help to clear that out. I hope this information is helpful to some degree. -Matt
Dec 16, 2014 | Frigidaire Dryers
Why is my dryer shutting off half way through and smell hot
Good Morning Friend,
I understand that your Frigidaire dryer, model# FFSE5115PW, is shutting halfway through the cycle, and smells hot. Please make sure that the lint filter, lint trap, ducting leading outside, and the outside ducting are free of lint. What can happen, is there is not enough air flow if these are clogged with lint, so your dryer will become hot and smell hot. This could possibly cause it to turn off as a safety feature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire White Electric Steam Dryer -...
Error code E64 comes up after the dryer run 2 munites, it gets warm then shuts off
the heating element most likely knackerd.............
cheers
May 25, 2014 | Dryers
Dryer isnt getting hot.smell a little burning smell.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 19, 2010 | Frigidaire Dryers
Problem for Frigidaire FSE748GF Dryer Brown marks on clothes - What could the problem be and how do you fix it.
If the clothes have a 'burned' smell, likely, the air flow through the machine is restricted and getting too hot. Vacuum out the exhaust hose and the outside vent of lint. Reach inside the machine's air outlet pipe and vacuum all that you can reach. Remove the lint filter and wash it in hot water and detergent to remove fabric softener deposits. Vacuum below the lint filter opening as far as you can reach and inside the door cavity (be careful of sharp edges!). Hope this helps!
May 16, 2010 | Frigidaire FSE748GF Dryer
I turn my dryer on and it immediately gets hot on the top of the dryer. So hot you would get a 2nd degree burn if you touched it. Then you can start smelling a burning smell. I've checked outside to make...
If this is as you say, please contact your appliance dealer as soon as you can. You are right, don't use it. You dont' want to be seriously injured nor injury someone else and as for your place catching fire, not a remote possibility.
Sep 21, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Bad smell
clean it with baking soda hot water and hair dryer
Feb 27, 2009 | Frigidaire FRT21H8 Top Freezer...
Hot electrical smell
take the back panel off and look for the melted peice. then you got it.
Jan 26, 2009 | Frigidaire GLER341A Electric Dryer
Dryer to hot
your dryer has 2 thermostats in it more than likely that no1 thermostat has burned out it will need replacing usually when u buy the stats they come in a pack of 2 lower and higher temperature stats
Aug 15, 2007 | Frigidaire FWT449
Dryers Logo
22 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
