Question about Integra DTR-5.1 Receiver
Arcam a19 will not return from standby mode using the remote controll
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
Tip
Digilogic DVDVCR2 Region Free Code Would you like your Digilogic DVDVCR2 to be...
Would you like your Digilogic DVDVCR2 to be region-free and play all DVDs? Here are the steps to make your Digilogic DVDVCR2 region free:
  1. Press the Standby button on your remote control to place the unit into Standby
  2. Press the Standby button on your remote control to turn on the unit
  3. Press the Open/Close button on your remote control to open the drive tray
  4. Press the Clear button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 3 button on your remote control
  7. Press the 6 button on your remote control
  8. Press the 9 button on your remote control
  9. Press the 0 button on your remote control
  10. Press the Open/Close button on your remote control to close the drive tray
  11. Press the Standby button on your remote control to place the unit into Standby
  12. Press the Standby button on your remote control to turn on the unit
Your DVD / VCR combo is now region free.
__________________________
Is your Digilogic DVDVCR2 locked in SAFE mode? View my other Digilogic tip to unlock SAFE mode.
on Apr 07, 2010 | Televison & Video
Tip
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
on Mar 07, 2010 | Televison & Video
Stereo amplifier remains in standby mode
You should be able to find a Universal remote that will cancel the standby function.
Mar 31, 2013 | Audio Players & Recorders
Arcam A65 amplifier keep on go to standymode why?
Depending on the volume level and how many speakers you are driving factor into how the amp will react. Check the speaker wires for shorts, if okay! then we must look at the audio output stage, if the semiconductors are getting to hot, the satety circuits will cause a shutdown, if you run a pair of speakers the amp will run cooler, if you recently added more speakers that would explain the shutdown, if not! there is a problem in the audio output transistors and ic's that will need to be dealt with.
Apr 14, 2012 | Arcam Audio Players & Recorders
Is there a code for multi regions for sony hcd s300
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [RETURN] Default Default region code on the player
[1] [RETURN] Region 1
[2] [RETURN] Region 2
[3] [RETURN] Region 3
[4] [RETURN] Region 4
[5] [RETURN] Region 5
[6] [RETURN] Region 6
[P. MODE] [RETURN] Only play DVDs with the selected region; auto switching OFF
[AUDIO] [RETURN] Default Auto switching ON
[ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
[SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision OFF)
[PREV] [RETURN] Enable user operation prohibitions* and access restrictions
[NEXT] [RETURN] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
Jan 12, 2010 | Sony DAV-S300 System
I bought my son a 19" philips tv model # 19pfl340d/27.in order to turn tv on it must be unplugged for 10-15 minutes.The first one I bought did the same thing and I returned it.this one is exactly the...
The remote control will not operate the TV when the TV is in the OFF mode (No LED lit on front bezel). To change the mode from OFF to STANDBY or ON, press the POWER button on the side of the TV. Once the POWER button is pressed, the LED will change to either red to indicate STANDBY or green to indicate ON, whichever mode the TV was in prior to being turned off with the TV POWER button.
By pressing the POWER button on the side of the TV, the mode will toggle from OFF to either STANDBY or ON. If the POWER button is pressed and then the LED on the bezel is red, the TV is in STANDBY mode and will need to be turned on using the remote control. If the POWER button is pressed and then the LED on the bezel is green, the TV is ON.
Nov 11, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
My Polytron TV is on standby mode. I used the remote but wont turned off
When you turn that TV "off" with the remote it go's into standby mode, that is the way they made it unfortunatly
To actualy make it not have any power going to it you will have to unplug it or plug it into a power strip and use the switch on the power strip.
They use the standby mode to allow the TV to turn on quickly without making you wait.
Jul 19, 2009 | Panasonic Televison & Video
Region cod
Multi-Region:
Feb 07, 2008 | Sony DVP-NS400D DVD Player
Integra DTR-5.1 Receiver Logo
48 people viewed this question
Top Integra Audio Players & Recorders Experts
Electro Med Services...
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
