Question about Kodak EKTAGRAPHIC III A Slide Projector
Slide projector is loading slides too fast
Slide projector is loading slides so fast you can't see them how to slow it down
    President:
  • Kodak Master
  • 412 Answers
On an Ektagraphic III-A there is an internal adjustment you can make of the wire that captures the slide change mechanism after one revolution (or ONE slide change). Over time and usage that wire either breaks off, burns off or gets out of adjustment. Look at the attached diagram for more detail:
slide projector is loading slides too fast - 23543734-wqxjnnjnpyv3l4lzvdkr51h2-4-0.jpg
Posted on Jan 05, 2015
SOURCE: My Kodak Carousel 750H slide projector will not
A common cause for that problem is a broken plastic "link" on the solenoid (Kodak part #217769). There are repair shops who can replace this part. It is very difficult to replace by yourself. http://www.kodak.com/global/en/service/repair/slideProj/index.jhtml
Posted on Nov 11, 2009
  • 412 Answers
SOURCE: I'm having a problem loading a tray onto my kodak
First, with the tray off the projector, cycle the projector several times in forward and then in reverse. Next, check to make sure the locking ring on the top on the slide tray is LOCKED ON TIGHT. Then turn the tray upside down. On a 140 Slide tray there is an index notch. On the metal plate there is a index hole. Gently release the metal spring of the tray latch and rotate the metal plate until the notch and hole line up. Now the tray should drop on the projector and index properly.
Posted on Dec 03, 2010
  • 412 Answers
SOURCE: Automatic slide changer is stuck in
The problem is continuous cycle (like you don't know that already...). It indicates that an adjustment to the cycle contact is necessary. To open the projector, first unplug it and remove the lamp module from the rear of the projector. Turn the projector upside down. Remove the 6 - T15 TORX screws from the bottom (5 around the perimeter and one in the channel next to the cord wrap). CAREFULLY pull the bottom off (the power wires connect the bottom cover & top together!!). Once you have it open, leave the projector upside down, put on your safety glasses & plug the projector into the wall. At the center of the projector you should see a hub rotating about every second or so. Above it you should see a "J"-shaped wire. See the attached illustration.
You will have to, in repeated steps, unplug the projector, bend the "J"-shaped wire GENTLY & SLIGHTLY, plug the projector back in and cycle it a few times. Check for the position of the "J"-shaped wire to the pad, and GENTLY repeat until you achieve the position shown in the illustration.
Posted on Dec 30, 2010
  • 412 Answers
SOURCE: will not change slides forward/backward, remote focus ok,
Your problem is most likely caused by a broken wire under the control panel or a wire somewhere in the "cycle circuit" that is no longer connected. You should seek out a factory-trained repair dealer who has a schematic that can trace down your projector problem.
Posted on Jan 04, 2011
  • 412 Answers
SOURCE: properly loading the slide tray
If the first slide is visable and consecutive slides are not, the "dark shutter" (a feature that prevents the eye-popping bright white screen when no slide is present) needs adjustment. A fairly easy adjustment for a factory-trained service dealer with the service manual and the correct tools.
How do you load slides in the tray and then into the projector?
place the slides upside down and in the way you will see them on the screen place in the tray
then place the end of the tray into the projector to the first click
from on it is a matter of pressing the next button
Feb 22, 2016 | Argus 500 Slide Projector
Change a carosul for 35 mm slide projector
Hi Richard, Turn the projector on, press & hold down the "Select" button. While holding the "Select" button down, rotate the slide tray to the "Zero" position. You will then be able to lift the tray from the projector. Good Luck!! Jim
Sep 23, 2014 | Office Equipment & Supplies
Kodak carousel 750H our carousel works except it does not slow down long enough to actually allow us to see the slides. The plug in remote seems to not have any impact whatsoever
The issue is the clutch contact inside the projector. The contact is either broken or out of adjustment.
The clutch spring protrudes from the hub of the mechanism camstack. The camstack makes ONE revolution for ONE slide cycle. The clutch contact stops the clutch spring at the end of the cycle, putting the projector in "idle", awaiting the next "cycle" signal. Based on your description, this is your problem area. Turn the projector upside down & remove the bottom cover. CAREFULLY remove the internal lenses with a CLEAN, lint-free cloth. Wrap each lens in a separate cloth, as the lenses can shatter if exposed to rapid temperature changes. Next, remove the lamp with another cloth & keep it wrapped, as well. CAREFULLY plug the projector back in (DANGER - EXPOSED VOLTAGE!!) & turn the projector to the "Fan" position. Look for the rotating camstack. Turn the projector on & off quickly to locate the straight wire protruding out of the camstack hub. Turn the projector OFF & UNPLUG. Now look for the "J"-shaped wire that SHOULD make contact with the clutch contact. You will need to re-form the clutch contact wire VERY GENTLY (the wire is brittle!!), so that the straight wire is JUST BARELY trapped by the "J"-shaped wire. Now plug in & turn the power switch to "FAN" to check that the camstack only makes ONE revolution. If it stops: GREAT !! If it still revolves multiple times, repeat the process until the camstack STOPS after ONE cycle. This should resolve your continuous cycle problem. Good Luck !! Jim
Jul 26, 2013 | Office Equipment & Supplies
Bell & Howell slide projector 454
go on line to bell & howell site and down load service manual or operators manual.
Jun 09, 2013 | Office Equipment & Supplies
Our Kodak projector 4400 advances the slides too rapidly (1 second or less each slide). This model does not have a variable automatic timer. Any way to slow it down?
The continuous cycle condition is caused by out-of-position cycle contacts. See the attached illustration for the correct position of the cycle contacts.
Jul 01, 2012 | Kodak Carousel 4400 Slide Projector
Will not load slide
Michael, Is this a Kodak projector? If so, will the tray lock in? Will it rotate if you hold down the "SELECT" button? Look at the slot in the top of the projector that the slides drop into - - is the slide lift lever in the "up" or "down" position with the projector powered on? If you answer these questions, I think I can help you diagnose your projector. Thanks!
Nov 06, 2011 | Office Equipment & Supplies
Kodak 4600 projector just jammed with full house viewing slides for first time in 30 years
I'm sorry for your presentation embarrassment.
The most common cause of slide jams is the 140-Slide Tray. Because to compartment width was designed to get the maximum number of slides in the defined Carousel circumference, the compartment width that each individual slide fits into is unforgivingly narrow at the hub. If your slides are like mine (and most other peoples), they are probably older. The cardboard mounts begin to de-laminate with age, causing a "dog-ear" effect on the corners of the slide. Because there is no room for out-of-spec slides, they rub on the way down (or the way up). The mechanism keeps chugging along, thinking the slide is in the gate (or back in the tray). Because the slide has slowed it's travel, the jam occurs.
My recommendation is to do one of 2 things: 1. Have your slides re-mounted. or 2. Buy some 80 Slide Trays and transfer your slides into them. You can buy them used in great condition on the internet pretty cheap.
If you have more questions, feel free to ask!! If I have helped, some kind words back to FixYa would be appreciated!!
Good Luck !! Jim
Mar 20, 2011 | Kodak Carousel 4600 Slide Projector
Kodak Carousel slide projector: The 'select' press-down button (which allows you to move the slide tray to any location) is stuck. So, no slides can be shown.
I'm not sure what generation Carousel you have. And I'm assuming in it's current state you can place a tray on the projector & rotate it all around, but no slide will drop. That means something is holding the slide lift lever it it's "up" position.
The SELECT button is spring-loaded, so that it should return to "button up / slide lift lever down" when the button is released. You can check to see if the spring has broken or unhooked (requires removing the bottom cover). Beyond that, this could be a jam in the slide change mechanism, which requires a level of training to diagnose. I recommend you contact a factory-trained repair dealer for assistance. The good news: parts are still available from: www.micro-tools.com
Good Luck !
Feb 08, 2011 | Kodak Office Equipment & Supplies
I'm having a problem loading a tray onto my kodak carousel 4400 slide projector any solutions?
Jan 14, 2010 | Kodak Carousel 4400 Slide Projector
I'm testing my 4400. With slide tray loaded (no slides in tray) when I advance the carousel the light from the lamp does not shine through. Does the carousel have to have slides drop down in order for the...
Yes!! The projector is equipped with a "dark shutter", which means light is only allowed to exit the projector when a slide is in the gate. That eliminates the "white screen strain" on your eyes when no slide is present. Happy New Year!
Sep 16, 2009 | Kodak Carousel 4400 Slide Projector
Kodak EKTAGRAPHIC III A Slide Projector Logo
195 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
