Question about Grohe Plumbing
Blocked spray head filter
How to disassemble and clean the spray head filters
  • 164 Answers
Could you show us a picture of the spray head?
Posted on Feb 21, 2014
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Whats with norpole 12000 btu window air conditioners w/FO CODE,now all i have is a expensive fan!
they eventually do need serviced by a good repairman .freon leaks out .control boards fail etc .
Jul 18, 2016 | Filter Heating & Cooling
How can I disassemble my bucket head wet/dry vac
use it for OR only( clean )-wet (not with large pieces of dirt in between) OR only dry with an accessory basketfilter but do not use it for switch
one time wet and sometimes dry again look the filter in the middle thats most important a float must allways be clean to protect the motor
because of the used filter many customers are switching not the basket filters if they use it for wet .thats goes wrong but to disassemble the screws are a four or six on the side where the filter is to release the top cover usually deep situated that Are posidrive screws.
Nov 12, 2015 | Bucket Head Vacuums
Dishes do not get cleaned
Look at the spray arm to see if any of the holes are plugged with calcium build up. Check to see if the arm pivots freely and nothing is blocking it from turning. If all these things look okay, check the filter screen at the bottom of the dish washer to see if it is partially obstructed. You may have to disassemble the filter to see inside it. If all seems ok, then look at a work water pump impeller which will reduce the pressure going to the spray arm.
Mar 29, 2015 | Kenmore Dishwashers
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
My dishwasher spray arms were clogged with calcium buildup so I cleaned one and replaced the other. I also removed the fixed disc-shaped device underneath the lower spray arm and found the particle filter...
you may want to check your hot water tank. It may need drained and cleaned, Or you may have the rod in the tank disintegrating. Also check you water faucet areators to see if they have calcium pieces too.
Feb 10, 2011 | Maytag Dishwashers
I have a Grohe Ladylux plus kitchen faucet very similar to this one, when I turn the water on there is a slight clunk and the water flow decreases. I am assuming I need a new valve but I havent' been able...
Before you start taking the whole faucet apart try taking the airiator or head of the end of the faucet. It may just be some sediment blocking the filter screen on the head. Unscrew the head and see if the water flows with the head off.
Jun 12, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Residue and small particles left in upper rack dishes and glasses. maytag mbh940aww dishwasher.Is there a filter to clean?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Yes there will also be a filter in the base of the unit to clean. This needs to be done regularly to avoid food getting into the working parts of the unit.
Jan 24, 2010 | Maytag Dishwashers
My Husqvarna blower, model 130BT, bogs down when it is revved up. It runs better when the air filter is removed although certainly not as well as should be expected. I took out the filter, cleaned and...
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 23, 2009 | Husqvarna Garden
How to clean a Anthony Apollo diatomaceous pool filter pump
Drain tank. Remove the retaining band from filter. release locking lever securing support shaft and lift straight up wiggling slightly. the filter grids will come out as a unit. A most satifactory cleaning can be done without disassembling the grids. Just hose of all surfaces with a strong spray of water. Clean out de from tank bottom. Clean tank o-ring, lube and reinstall grids.
Mar 25, 2009 | Pool & Spa
Plumbing Logo
106 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
