Question about Kitchen Ranges
The electronic clock stopped working.
There was a power outage and the electronic clock is blank and does not come on now.
SOURCE: Display area and clock will not re-set on Electric Range
on any appliances need to know the model and serial num some problems are model specific
Posted on Dec 28, 2007
jsrock516
  • 5911 Answers
SOURCE: oven burnout
The oven is controlled by an Electronic Range Control (ERC). This is the clock assembly on the range. The surface elements are powered by infinite switches and do not go through the ERC. That explains why the clock assembly is dead, your oven does not work, but your surface elements do. You need to replace the ERC. If you can provide me with a model number (located near the oven door or bottom drawer opening on most ranges, on the back of the console on some) I can determine what type of ERC you need and how much it might cost you. Post back with comments and let me know if I can be of further assistance. I hope this helps you.
Posted on Feb 11, 2008
SOURCE: Inglis Royal electronic stove. Wehad
To set the time. The top strip on the upright part of the stove , where the clock is, flips up. The directions are under it.
Posted on Jul 11, 2008
  • 311 Answers
SOURCE: Blank display on Clock/Oven Controls
Control is bad if it is getting power- needs to be replaced. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Posted on Dec 01, 2008
SOURCE: whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
Posted on Mar 24, 2009
How do we operate the clock radio with batteries?
Anise, most clock battery backup's will most likely just keep the time setting on the clock until power is restored rather than actually power the clock radio during a power outage.
Apr 15, 2018 | Power Computers & Internet
We have an XE-A217W which has decided not to work following a power failure. The printer still scrolls but the screens remain blank
Hi Trevor.
By 'scrolls' I guess you mean 'feeds paper'?
If display screen is blank since the outage, try switching off and unplugging the printer for a minute or so, then re plug.
Unfortunately, a power outage often results in surges and brownouts while power is being restored, which can disrupt or damage electronics and electrical devices.
The board may have fried.
Nov 23, 2017 | The Office Equipment & Supplies
How do I fix A clock that has not worked since a power outage
The cooking environment is not really clock-friendly and it is amazing cooker clocks and timers last as long as they do. If it is a mechanical clock it is likely to be driven by a synchronous motor. When that type of motor starts sometimes they run backwards and need stopping again. Sometimes they just don't restart and need a tap or flicking the adjustment controls might work. Could be it needs cleaning or perhaps it is worn out.
If the clock is electronic, it must be remembered a power outage is often accompanied by a damaging current surge.
I suggest you remove the clock and check the supply. If the supply is ok the clock is faulty.
Jan 03, 2016 | Kitchen Ranges
Frigidaire CPEF3081MFC - Clock and timer run fast [gaining approx. 10 mins per hour]. Everything else, including temperature, functions normally.
If the power outage was as a result of a power surge it is likely that
the components were affected in some way, they may need diagnosing and repair or replacement.
There are many reports of electronic devices going wrong after
a power cut...the outages are , seemingly responsible for a lot of damage. If this is the case I would look at whether there is a mechanism for claiming reparatory compensation from the power company you are signed to
Jul 03, 2015 | Kitchen Ranges
I am looking to get a Malibu digital landscape transformer, such as model # 8100-9045-01, and I'm wondering if they have a "memory backup". In other words, every time there is a temporary...
8100-9045 is rated for 45 watts.
That's two 20 watt bulbs, or three 15 watt bulbs.
Power outage carryover: Contact Malibu directly since there is conflicting information on Malibu site:
http://malibulights.com/customer_service/contact_us.aspx
8100-9045-01 45-watt power pack page on the support tab says 'loss of power will stop timer.'
And then mentions tripper.
http://www.malibulights.com/products/transformers/details.aspx?item=8100-9045-01
http://malibulights.com/products/transformers.aspx
However other information on Malibu wesite contradicts power-outage information and shows 8100 series timer is electronic and is controlled by photoeye, and that timer has no tripper.
http://waterheatertimer.org/images/Malibu-8100-series-400.jpg
As a general rule with electronic timers, there is battery or capacitor carryover.
Aug 20, 2011 | Hardware & Accessories
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
The electronic oven control my whirlpool GS470LEM is blank.
Check the breaker to see if it is tripped turn it off and back on,
Jun 01, 2009 | Whirlpool GS470LEM Gas Kitchen Range
Clock on a GE electric range is buzzing - how to disconnect it
Turn off power to range first!!!
You'll have to remove the back of the panel in which the clock is installed to access the back of the clock. There will be two wires attached to the clock. Just pulling one of these wires off will stop the clock.
I would suggest, however, that you pull both wires off, put electrical tape on the ends of the connectors, and tuck them out of the way somewhere around the clock.
May 03, 2009 | GE JBP30 Electric Kitchen Range
Whirlpool electric range won't work
Mar 24, 2009 | Whirlpool RF368 Electric Kitchen Range
Kitchen Ranges Logo
11 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
