Question about Omega MARS-22 Remote Vehicle Starter with Keyless Entry
Cruise control on 08 avalanche not working - Omega MARS-22 Remote Vehicle Starter with Keyless Entry
Cruise control won't turn off
by cruise control being PCM control have dealership code scan see what causing cruise control turn itself on.
Apr 18, 2013 | Infiniti Cars & Trucks
Cruise control stopped working on a 08 Chevrolet HHR
I just got the perfect answer to this yesterday. It's a $5 fix! Check your brake lights. If any of them are out, it will make the cruise control not function. Turns out all 4 of the 3rd set of brake lights were out. We replaced the 4 of them and the cruise control immediately became functional again. I got this tip from a gentleman in the service department at a local Chevy dealer.
Feb 14, 2013 | 2008 Chevrolet HHR 2.2
2011 cruise control and remote start do not work after EVAP problem.
the remote start and cruise control will not work if the codes are stored just because the light is off doesn't mean the codes are cleared
Jul 19, 2012 | 2011 Chevrolet Avalanche LT
2007 Avalanche cruise control doesn't work even though the steering wheel switch is lit. Fuse is not blown and backup camera works.
i just had the same problem, it started after having to get a "jump start" for a low battery. after checking the fuse(under the hood #43) I disconnected the battery for about 60 seconds to let the computers reset. works fine now. don't know the original cause of the low battery, or the fault but don't want to pay the dealer service charge for doing the same thing...hope this helps ..billy
Feb 08, 2011 | 2007 Chevrolet Avalanche LTZ
08 avalanche pass side power door lock not working
if you have any knowledge of automotivce electrical, (and that you need to use a "circuit tester" and not a test light) test for power when someone presses the button. it wouldnt be uncommon for most vehicles for the lock actuator/solenoid/duty actuator to wear out, get weak and fail. this is most probable. given that this is an 08, have you checked withe dealer to see if its still under warranty. if we are only talking a few miles and they wont do anything, look in your owners handbook and get the 1 800 number and get GM's customer service involved. cheers.
Dec 02, 2009 | 2008 Chevrolet Avalanche
Cruise control inop
Could be a bad vacum dump switch on the brake pedal. There is 2 switches on the brake pedal one for brakes lights and one for cruise The cruise switch must be pushed when the pedal is up. Or your servo under the hood is bad To identify the parts go to the parts store and look at them and you will know what to look for
Mar 28, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Omega MARS-22 Remote Vehicle Starter with Keyless Entry Logo
Top Omega Juicers Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Omega Juicers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
