Question about Whirlpool RBD305PD Electric Double Oven
Clock colons keep flashing on whirlpool oven sf385pee
HOW DO I SET THE CLOCK ON MY NEW BOSCHE BUILT-IN OVEN MODEL HBE5451UC?
Read the owner's manual.
After connecting the oven or after a power failure, 1. Hold the TIMERS button down until the colon blinks on the display.
2. Set the current time with the @ and A buttons. Hold the @ or A button down to change the value faster. The time set is taken over after 5 seconds.
Jul 24, 2016 | Ovens
After a power outage, the oven control light keeps flashing.
You have too reset clock pressing two buttons works for me
Nov 09, 2015 | Ovens
Whirlpool oven model RBD245PDQ15
Replace the display/control pt # W10340941, it can be purchased at www.repairclinic.com or www.apdepot.com
Apr 24, 2012 | Whirlpool Ovens
How do i set clock and keep it displayed on a whirlpool gold accubake oven
http://whirlpool.custhelp.com/app/chat/chat_launch will give you a chat line where the Whirlpool expert will chat with you and help you get your problem solved
Nov 07, 2011 | Whirlpool GBD307PDS Electric Double Oven
Am getting an e1 f1 error code on whirlpool super capacity natural gas oven model sf385pee please help if you can, thanx
HI. this will be a EEPROM check-sum error code. Follow the instructions below to address this issue.
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Oct 14, 2009 | Ovens
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
The clock on my wall whirlpool oven flashes a error code of F2 and beeps on and off?
F2-- Oven temperature is too high
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Jul 09, 2009 | Whirlpool GMC275PRS Oven
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Display
Need new electronic module
Jun 14, 2007 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBD305PD Electric Double Oven Logo
18 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
