Question about Canon PowerShot SX130 IS Digital Camera
PICTURES NO LONGER TRANSFER TO MY COMPUTER
I GOT A NEW TRANSFER CORD BUT AM STILL UNABLE TO TRANSFER MY PICTURES FROM THE CAMERA TO THE COMPUTER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Posted on Nov 20, 2014
5 Suggested Answers
MrsJGreen
  • 130 Answers
SOURCE: can not download pictures
Your OS may have updated and not provided the driver for the camera. Try any or all of these steps that apply to your situation.
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Posted on May 30, 2008
  • 57 Answers
SOURCE: canon power shot s1 is our camera suddenly ..
It is possible your USB connector has been damaged on the camera. This should be a relatively cheap fix however sometimes the circuit could also be damaged by a spike of power comming from the computer side. If it is found to be the later, you could be up for more than a new camera is worth. I would recommend purchasing a USB Compact Flash card reader to access your images off the card directly. They are relatively cheap to purchase from a computer store and easy to setup. Good luck.
Posted on Apr 15, 2009
Kuwagata
  • 181 Answers
SOURCE: Problem transferring pics with the Canon Powershot SD750
Replace the USB cables, it should work..........
Posted on Dec 08, 2009
  • 433 Answers
SOURCE: Pictures won't transfer from my camera to either
use what I call a multi stick, accepts 7 different memry cards in a USB stick, and down load from that
Kingstong made mine.
Posted on Feb 10, 2010
My mother owned a casio camera and transfered
After you insert the disc, does it open showing you the files? If so, copy them to a folder you create on your desktop. Once there, you should be able to open them. If not, you could take the disc to Walmart and use a Kodak Picture Kiosk machine to either print them or make a new copy of the cd. The make of the camera has nothing to do with opening the pics on a computer.
Mar 11, 2010 | Casio QV-R40 Digital Camera
Transfering pictures from camera to computer
Use a card reader instead of your camera.
Dec 26, 2009 | Cameras
Camera not recognized by computer
Oh, I had I this problem last week. My drivers were outdated and I used this software:
http://www.windowsdriverhelp.com/landing/driver/wdh/driver.php?key=nikon p80
Sep 08, 2009 | Nikon COOLPIX P80 Digital Camera
My pictures won't download!! I never had this problem before, so I don't know whats going on? I plug in the usb cord, and the camera turns on and everything, but the thing will not pop up where it usually...
some comp seem to have problems reading from the olympus cameras. if you have a card reader take the card out and put into that. if not you can get one cheap and they simple to use
Jan 30, 2009 | Olympus FE-340 Digital Camera
Unable to transfer pictures
Just get a card reader and insert the smart card from the camera into it. It will show up as a drive on you computer. Go into the DCIM file and your pictures will be in there.
Nov 25, 2008 | Nikon Coolpix S51c Digital Camera
Transferring pictures
you can go to your control panel and go to "add new hardware" icon. them you can search for plug-and-play devices such as youe camera
Jun 15, 2008 | Nikon Coolpix 4600 Digital Camera
Missing computer cord
does your camera have a usb connection ? because if it does you can buy that at places like walmart,or special electronic places. or you might have to go to a place where they does pictures and get them to download all of the pictures to a cdrom
Sep 02, 2007 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Canon PowerShot SX130 IS Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
