Question about Jenn-Air JS48SEDBDA Stainless Steel Side by Side Refrigerator
JS48SEDBDA drain tube - Jenn-Air JS48SEDBDA Stainless Steel Side by Side Refrigerator
Ice forming under the freezer drawer & on drain tube water pooling in floor Cleared drain tube, what else?
Whirlpool corp., whom made this unit, had a bad design for the defrost drain tube by the compressor. Order part W10619951 and install. This is a kit to change out the current drain tube to a better one. You still have to defrost the frozen defrost drain tube but this will fix it for good.
Aug 01, 2015 | Maytag MFI2269VEM Monochromatic Stainless...
Jenn-Air JS48SEDBDA, sn 1271791 will not cool both freezer and refrigerator
The number reason for the Jenn Air no cool situation is caused by a break down of hte PAG oil in the compressor, thus clogging the capilary tube at the filter drier area, and causing contamination within the system. Per the Maytag TSB, a new compressor kit, heat exchanger, and new liquid line drier are required to be replaced. The compressor kit should come with a new main logic board. The ramaining componants need to be completely purged with nitrogen till clean. The condensor coil must be clean and free of any dust. A new lower freon charge follows the completed repair, and replacement decal to show new charge.
Nov 26, 2012 | Jenn-Air JS48SEDBDA Stainless Steel Side...
I have a 2006 saturn ion 2. Just recently, my ac is draining into the passenger floor board. How do i fix this ?
Bulletin No.: 03-01-39-011B
Date: November 22, 2005
TECHNICAL
Subject:
Water Leaks Into Passenger Compartment Through HVAC Module Condensate Drain Tube When Parked on Incline/Uphill Position (Install Auxiliary Drain Tube Extension)
Models:
2003-2006 Saturn ION Sedans and Coupes
Supercede:
This bulletin is being revised to include the 2005 and 2006 model years. Please discard Corporate Bulletin Number 03-01-39-011A (Section 01 - HVAC).
Condition
When vehicle is parked on an incline with the front end up during a rainstorm or when driving uphill during a rainstorm, water may leak into the passenger compartment through the condensate drain tube opening of the HVAC module.
Cause
Water may drain out of the cowl drain, then drain down the front of the dash panel in the engine compartment and seep into the HVAC module condensate drain tube opening. The water then collects in the heater core cover and upon acceleration may leak into the passenger compartment through the heater core cover seams.
Correction 1. Open the hood and locate the HVAC module condensate drain tube in the engine compartment on the right side of the dash panel.
Important: During installation of the auxiliary drain tube, do not make contact with the HVAC module foam gasket located at the base of the HVAC module condensate drain tube. If the auxiliary drain tube is pushed on too far and makes contact with the foam gasket, water may leak into the passenger compartment.
2. Slide the auxiliary drain tube onto the HVAC module condensate drain tube and make sure that the auxiliary drain tube is angled downwards after installation.cansmo_121.gifcansmo_122.gif
Aug 28, 2011 | Saturn Ion Cars & Trucks
The freezer is not as cold as it should be. Is 2 the coldest setting? Shouldn't 4 or 5 freeze ice cream hard? Thank you. Jim
Hi Jim,
I am currently working on that model for a friend, the higher number the colder that compartment will get, it is not advisable to go any higher than 5 or 6, because this will reduce air to the refer section. Is the fan working in the freezer? I have seen problems with this model, and when the drain pan to the evaporator clogs, then the water freezes around the fan motor and stops it from functioning.
Get back to me and I could lead you in the right direction if needed.
Aug 14, 2011 | Jenn-Air JS48SEDBDA Stainless Steel Side...
I have a AMH95 gas fired furnace. there are 2 drain tubes on the back of furnance that drain water when the central air is running. One tube runs to a tube that runs to a floor drain and the other just...
Hello RR,there are 2 tubes one is the PRIMARY drain & the other is secondary drain.If the primary drain becomes CLOGED or slows down the 2nd drain leaks.Its time to clean out the primary drain tube.Find the end or disconnect it & blow/flush it out to clear it.
Aug 09, 2010 | Heating & Cooling
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
Refrigerators Logo
16 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
