Question about HP DeskJet 960c InkJet Printer
Will not print at all
Color cartridge low, yellow light blinking. installed new color cartridge, yellow light continues to blink, nothing will print at all. powered off printer, took both cartridges out & reinstalled. restarted computer. still no printing, & yellow (lo ink) light still blinking. any suggestions????
  • 2 more comments
  • Anonymous Aug 01, 2008
    won't print orange light blinking. I've unplugged it help!!
  • Anonymous Mar 14, 2014
    msp star printer print light continuous blinking
  • Anonymous Mar 22, 2014
    Initializing stops and posts D6 error with yellow color light on.
  • Anonymous Mar 28, 2014
    new cartridge, yellow ink prints green
  • 4,889 Answers
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Posted on Oct 27, 2007
Reset your cartridge
Posted on Jul 16, 2008
Yellow light is blinking?
If the bottom amber colored light is blinking, the imaging drum needs replaced.
If the yellow print cartridge light is blinking, then replace the print cartridge (yellow toner).
Mar 24, 2014 | HP c9705a - Color Laser Jet 2500l Printer
Yellow ink blinking
Please clean the printhead using the software installed in your PC . Try printing now.
Apr 30, 2010 | Epson Stylus Photo R2400 InkJet Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
The yellow light blinks and it won't print
I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
Jan 21, 2009 | HP Deskjet 870cse Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Flashing Lights
From the User Guide:
Black, Cyan, Magenta, and Yellow Supplies Status lights
These lights indicate when a print cartridge is low (the light is on), or empty or missing (the
light blinks). The lights also indicate when a non-HP print cartridge is installed (the light
blinks and the Attention light is on).
If you don't have a User Guide click on the link below and save it for future reference.
2550n User Guide
If this solution has been helpful, please rate it. Thanks!
Jul 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Hp lazerjet 2550n
Your Black cartridge is empty.
From the user guide:
Here is a link for the User Guide:
2550n User Guide
If this solution has been helpful, please take a moment to rate it. Thanks!
Jun 16, 2008 | HP Color LaserJet 2550n printer + HP Color...
Power Light Continues to blink.
if you are having issues after installing the new cartridges , then perform the following steps.
unplug the power adapter and remove both the cartridges and then power on the printer , look for the power light. if it does not blink then .
install the black cartridge first and then try to print , if it prints fine its ok. then remove the black cartridge and then put the color one in and then try printing or copying .
if it doesnot print with any either black/ color then you have to replace that particular caratridge..
lemme know once u r done....
May 02, 2008 | Lexmark X1270 All-In-One InkJet Printer
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
HP DeskJet 960c InkJet Printer Logo
1,193 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
