Question about Pyle PLBT72G 7 Single DIN In-Dash Motorized Touch Screen TFT/LCD Digital Monitor w/DVD/CD/MP4/USB/SD-Slot Card AM/FM/RDS/Bluetooth Dial Pad Built-In GPS/TTS w/USA/Canada & Mexico Maps
Rds selection disabled
Cannot select rds options
How to disable the video on a A780L motherboard
North Bridge Co nfig uration
BIOS SETUP UTILITY
Chipset
vxx.xx (C)Copyright 1985-200x, American Megatrends, Inc.
Select Screen
Select Item
Go to Sub Screen
General Help
Save and Exit
Exit
Enter
F1
F10
ESC
NB Chipset Configuration
NB CIMx Version : 4.4.0
> PCI Express Configuration
Primary Video Controller [PCI-GFX0-GPP-IGFX]
NB Power Management Features [Auto]
> Internal Graphics
Internal Graphics Conf
Internal Graphics Configuration
BIOS SETUP UTILITY
Chipset
Select Screen
Select Item
Change Option
General Help
Save and Exit
Exit
F1
F10
ESC
Internal Graphics
UMA Frame Buffer Size [Auto]
FB Location [Above 4G]
AMD 780L HD Audio [Enable]
Internal Graphics Mode [UMA]
Surround View [Disabled]
Options
Disable
UMA
T his item allows you to select the memory mode used for internal graphi cs device.
Options: UMA (Default) / Disable
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiwq5ik2rXQAhWKP48KHU--AYMQFggcMAA&url=http%3A%2F%2Fmediapool.getthespec.com%2Fmedia.pdf%3Fm%3DQNJ2kCQfmVPhBYToYbwEQw%253D%253D%26v%3DPD&usg=AFQjCNGEH6Nge9c54_Uk8domc9vJiL0eTw
Nov 19, 2016 | Computers & Internet
Tip
PC sleep mode problem?
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the
Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control
Panel.
2)Click "System and Maintenance," and then select
"Power Options."
3)Select "High Performance" to disable the overall sleep
mode. The monitor will still go into sleep mode unless
you click "Change Plan Settings" and disable all sleep
options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans,"
and then click "Change Plan Settings." Change all of the
options to say "Never."
on Dec 17, 2010 | Computers & Internet
Want to delete ask
- for Google chrome
go to settings and you find the Search > under it select your search engine that you want to keep.
- for Firefox
Go to Tools from menubar > Select Add-on > in Add-on page you find Plugins option > in plugin option select the Ask and disable it.
- for Internet Explorer
from menubar click on Tools and select the Manage Add on >
then in add on windows > click on Search Provider option, In it you can find Ask add-on. select it and click disable.
Mar 22, 2014 | Computers & Internet
Cant change my messaging from dictionary to odinary text
To disable predictive texting on Motorola V360:
  1. Select the "Texting," "Text Messaging" or similar option on the menu screen.
  2. Choose the "Text Options" or "Options" selection on the "Text Messaging" screen. Choose "New Message" or "New Msg" if no "Options" selection is available, then press the button associated with the "Options" selection found on the blank message screen.
  3. Select "Entry Mode" on the screen. A list of options appear.
  4. Select a non-iTap mode, such as "Symbols" or "abc2." Press "OK." The iTap entry mode is disabled.
Jun 27, 2011 | Motorola Mobility V360 Cellular Phone
The flashplayer is installed on the computer but whatever programme I gointo theprompt says "installflash player"
You may have to go into the control panel and select add / remove programs (xp) or programs and settings (vista /7). Select Adobe Flash and remove it. Open your browser to http://get.adobe.com/flashplayer/otherversions/ and reinstall the player. Select your operating system and in the version selection, highlight the newest version for the web browser you are using. If you aren't using a browser listed, select the 'other' version.
If you still get those errors after reinstalling flash, you may have the add-ons disabled in your browser. You can enable / disable browser plugins in Internet explorer:
Open Tools > Manage Add-ons Make sure that for Add-on Types the Toolbars and Extensions option is selected Make sure that Show the Currently loaded add-ons option is selected Select the flash item and if it shows disabled, enable it.
Regards, Chris
May 18, 2011 | Macromedia Computers & Internet
My hp L1506 going to sleep again and again
In windows XP
"Apply," "Okay" and "Okay" once again to close the Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control Panel.
2)Click "System and Maintenance," and then select "Power Options."
3)Select "High Performance" to disable the overall sleep mode. The monitor will still go into sleep mode unless you click "Change Plan Settings" and disable all sleep options.
In windows 7
3)Select "High Performance" under "Additional Plans," and then click "Change Plan Settings." Change all of the options to say "Never."
Dec 16, 2010 | HP L1506 15" LCD Monitor
WR-100 Weather/RDS Radio: need alerts for multiple counties...
  1. Press the "Menu" button.
  2. Use the up arrow until you see "S.A.M.E SET" on your screen.
  3. Press "Select".
  4. Use the up arrow until you see "Multiple".
  5. Press "Select".
  6. Press "Select".
  7. Program your first S.A.M.E code.
  8. Press "Select"
  9. Press "Select"
  10. Program your S.A.M.E code.
  11. If you have more S.A.M.E codes to program, repeat steps 8 - 10.
  12. Press "Menu" to exit.
May 17, 2010 | Midland WR-100 Weather/RDS Radio
How do i set the clock on a 2004 ford explorer
Page 20 of your owner's manual for PREMIUM AM/FM STEREO/CASSETTE/SINGLE CD:
RDS: (Radio Data System): Press RDS to access the clock mode.
Setting the clock: Press RDS until SELECT HOUR or SELECT MINS is displayed. Press SEL to increase (◄) or decrease (►). Press RDS again to disengage the clock mode.
or
Page 26 for PREMIUM IN-DASH SIX CD SOUND SYSTEM
Setting the clock: Press MENU until SELECT HOUR or SELECT MINS is displayed. Use SEL to manually increase (▲) or decrease (▼) the hours/minutes. Press MENU again to disengage clock mode.
Nov 18, 2009 | 2006 Ford Explorer
Blackberry call barring
To disable call barring
1. On the Home screen, click the Phone icon. The Phone screen appears.
2. Click the trackwheel to view the menu, and then click Options. The Phone
Options screen appears.
3. Click Call Barring. If your SIM card is provisioned for call barring, the Call
Barring screen appears.
4. Select the call barring option that you want to disable and click the trackwheel
to view the menu. Click Disable.
5. Click the trackwheel to view the menu, and then click Save.
You return to the Phone Options screen and your call barring option is disabled.
Jun 19, 2009 | RIM BlackBerry Bold Smartphone
Need to change the 12v supply by the Radio
The Ford Focus has a stereo problem where the display blinks on and off, with or without the ignition on. This is not a power problem.
This problem occurs when attempting to store a radio station when a blank RDS signal is being transmitted.
To restore your stereo:
  • Insert a CD, stereo will turn on in CD mode.
  • Press MENU button
  • Select DEFAULT RESET by turning the right rotary knob and press to select
  • Select YES by tuning the right rotary knob and press select
  • Press BACK button
  • Press the RDS button once, display will read RDS OFF
  • Stereo will now work properly
To prevent this problem from occurring again, be sure some text is in the top line of the display when setting a stereo station. Do not set a station when the station name is blank in display.
Nov 16, 2008 | 2006 Ford Focus
Pyle PLBT72G 7 Single DIN In-Dash Motorized Touch Screen TFT/LCD Digital Monitor w/DVD/CD/MP4/USB/SD-Slot Card AM/FM/RDS/Bluetooth Dial Pad Built-In GPS/TTS w/USA/Canada & Mexico Maps Logo
16 people viewed this question
Top Pyle Computers & Internet Experts
Stan Skaggs
Stan Skaggs
Tom Chichester
joel maureal
Are you a Pyle Computer and Internet Expert? Answer questions, earn points and help others
