Question about Precor 9.25 Treadmill Repair Parts Eprom 37979-106
Manual precor 9.25i
What type of lube
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
seconds
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
When walking on treadmill it stick like it want to stop
This sounds like either 1 or 2 things. Either the belt is worn to the point it needs to be replaced or the belt and deck need to be lubed. The video below will help you by showing you how to apply the lube and link below will give you an option to purchase the new belt and deck. Please use your model and serial number to narrow down your choices.
Precor Repair Parts for 942 944 Treadmills SPORTSMITH net
Dec 11, 2013 | Precor Treadmill Belt 940, 942, 944...
The treadmill shuts down as I go faster
This happen because the lack of LUBE maintenance schedule
Lube with 100% silicones or wax see your instr. manual
2) Lube the rollers bearing. with wd-40
3) test the drive belt motor.
4) Test the input voltage motor, if there are the motor need repair
see my personal TIPS for motor help
5) Test the output board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Dec 05, 2012 | Precor 9.31 Treadmill
Error 32
LUBE OR wax you deck belt, this happen for autoprotection electronic system. To due a lack of LUBE maintenance schedule.Do it right now according with owner manual.
2)lube THE rollers bearings too use WD-40 for the bearings only
3) Test the drive belt motor, for cracking or worn belt, replace or adjust in according.
4) Test the motor voltage input, if there are the motor need repair, see my personal TIPS for troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 16, 2012 | Precor C966i Treadmill C 966i
I have a precor 9.2s I use it every day for about 40 minutes but lately smell like something is burning but it does not stopped dont know what is
1) LUBE the deck belt, this happen because the lack of maintenance schedule. maybe your have a WORN deck belt.,time to replace
2) LUBE the rollers bearing very well too
3) test the motor for maintenance repair.
see the block diagram, and see my personal TIPS.
God bless you
Oct 17, 2012 | Precor 905e 9.2 9.20 9.20s 9.1 9.2s Motor...
I have a precor 9.3 treadmill that works until you i start running on it, what is the cause?
1= LUBE the deck belt , this happen because enough friction produce shut down, for to protect the electronic system.
2= LUBE the rollers bearings too
3= measure the input voltage motor, if there are the motor need repair
4= measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block
God bless you
Jul 19, 2012 | Precor 933 Premium Series Treadmill
I have a precor 5.23 ellipital. I am getting a clicking sound what can i do
1) just tight any bolt and nut with socket wrench. and tight any wires connector. Of course your unplugged the machine before to do anything.Lube according with the instr. manual you can download from free. www. fitness.manualsonline.com and proceed according.
2) tight very well the magnet, and tight with the bolts and nut, and test with the magnet from refrigerator, for attraction or repel, and replace.
God bless you
Jun 28, 2012 | Precor Efx-5.23 Elliptical Machine...
Have a precor 9.20. After using about 15 min. I am smelling something like Maybe motor buring? Should I try to lubricate?
First, inspect the walking deck for damage (scratches, gouges, worn surface) and check the belt for wear. Feel the outer edge of the underside of the belt, then the center. The center should be rough like the outer edge. If it is smooth or fuzzy, the belt is worn out. If deck and belt are OK go ahead and lube the deck. I think Procor uses a standard parafin wax you buy at the grocery store, but check your manual to be sure. Apply the lube to the walking deck and try the machine again.
Feb 26, 2011 | Precor 9.21 Treadmill
Precor 9.25 Treadmill Repair Parts Eprom 37979-106 Logo
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
