Question about Frigidaire ATF6000ES Front Load Washer
My frigidaire model #LTF7000ESO makes the sound like it is spinning but never does at any time during the wash cycle. How do I fix this??
  • Frigidaire Master
  • 5,323 Answers
MOTOR COUPLER
Posted on Apr 01, 2015
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
  • 220 Answers
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
If you want to take the time, I just replaced my drum bearings and seal for $62.00. No really any special tools needed. My model showed the bearings were not sold seperately and you had to buy the complete tub half, but when you take it apart, you can knock out the bearings and buy them online or at a bearing house. I have a seal part number also.
If I remember right the bearing part numbers are 6306-2RS and 6307-2RS (1 each) and the seal is a 40mmX80mmX10mm thick. Make sure you get the -2RS bearings because they are sealed. The ones that came out of mine are shielded bearings ( -Z ) and they will not resist moisture if the seal shaft seal fails.
Most AutoZones have seal and bearing drivers you can "borrow". They really help during installation so you don't deform the seal or damage the new bearings.
Any good bearing house should be able to macth on up or if you post back I can give you the exact number. I think most brands of front washer use the same bearings, but you may want to take yours apart before you buy.
Worst case the junk yard doesn't care if it comes in pieces or as one piece. Give it a try.
Not sure you will want to get this involved, but its not really too bad of a job.
Posted on Dec 31, 2008
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
rylee_smith
  • 8619 Answers
SOURCE: Frigidaire FWS833AS1 - My washing machine recently
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 16, 2009
SOURCE: My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Posted on Feb 14, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
My front load Model LTF7000ESO will not spin at during entire wash cycle. ow can I fix this??
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Feb 15, 2014 | Frigidaire Washing Machines
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Model FWT449GFS1 Frigidaire Gallery problems: roaring during spin cycle, worsening drum won't turn manually and this last run, was making sounds like slipping belt. During drain time, can hear coin in...
most likely transmission bearings are worn out (sounds like a jet plane taking off) unfortunately this requires replacing the transmission which is a costly job.
Sep 07, 2009 | Frigidaire ATF6000ES Front Load Washer
Aug 02, 2009 | Frigidaire ATF6000ES Front Load Washer
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Frigidaire ATF6000ES Front Load Washer Logo
73 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
