Question about MSI NX7600GT-T2D256E GeForce 7600GT, (256 MB) PCI Express Graphic Card
Video card is not recognized by the motherboard
    Sergeant:
  • 281 Answers
Are you saying that when the card is plugged in the MB doesn't see the device?
If so then it seems to be a hardware issue to me. Could be the PCI-e slot on your MB is malfunctioning. Could be dirty contacts on the card even (try cleaning the card slot contacts with rubbing alcohol)... Or it could even be the card itself is not functioning.
Posted on Jan 30, 2015
    Habit-Forming:
  • MSI Expert
  • 89 Answers
Use this software, and follow the steps:
Guru3D - Driver Sweeper
Guru3D - Driver Sweeper is a fast tool to remove driver leftovers from your system. It's very important to remove your drivers on a proper way, because driver leftovers can cause problems like stability and startup problems. You can use it if you want to update/remove drivers from your system.
How to use ?
video card is not recognized by the motherboard - video-card-not-recognized-motherboard-bsgsyvatoo5tbjj50gcrqdfu-5-0.jpg
There are two methods to use Driver Sweeper.
Both methods achieve the same results. This method is always able to clean all files.
This method will delete remaining files upon reboot (if deleting failed). You can clean your drivers this way:
  • Use the official uninstaller(s) of the driver(s) you want to uninstall.
  • Reboot your PC in Safe Mode.
  • Run Driver Sweeper and select what to clean.
  • Analyse lists all the entries possible to remove, cleaning removes the entries selected.
  • More drivers can be selected for the same cleaning process.
What can it be used for ?The current supported drivers are NVIDIA (Display and Chipset), ATI (Display), Creative (Sound) Realtek (Sound), Ageia (PhysX) and Microsoft (Mouse).
All the settings are saved in an ini file. Nothing is created in the registry, so it's possible to use it as a portable program. Log files can be saved to the harddisk and viewed as well. You can find the logs under the Tools menu.
Driver Sweeper has been replaced with Display Driver Uninstaller. Display Driver Uninstaller Download version 13 6 0 0
The AMD/NVIDIA video drivers can normally be uninstalled from the Windows Control panel, this driver uninstaller program was designed to be used in cases where the standard driver uninstall fails, or anyway when you need to thoroughly delete NVIDIA and ATI video card drivers. This software is backed by Guru3D.com
The current effect after you use this driver removal tool will be similar as if its the first time you install a new driver just like a fresh, clean install of Windows. As with any tool of this kind, we recommend creating a new system restore point before using it, so that you can revert your system at any time if you run into problems.
If you have problem installing older driver or newer one, give it a try as there are some reports that it fix thoses problems.
We have an extensive AMD support thread over here and an NVIDIA over here.
Recommended usage
  • The tool can be used in Normal mode but for absolute stability when using DDU, Safemode is always the best.
  • I would like to gather feedback from you guys. Tell me if it was success or not.
  • Make a backup or a system restore (but it should normally be pretty safe).
  • For people with driver problem, if this tool gave you any success into fixing some issues your are currently experiencing, please share your result.
Keep note that NVIDIA/AMD did not have anything to do with this, I do not work at or for NVIDIA/AMD and they should not be held responsible for anything that may go wrong with this application.
NOTE: .NET framework 3.5 Required - Windows XP up to 8.1 is supported X86/X64 (not sure for WinXP x64)
Driver Sweeper has been replaced with Display Driver Uninstaller. Download here.
Posted on Jan 14, 2015
Motherboard da061l3d on board video quit working.
you need to go to cmos to do that.be careful if you do not know how to do that .
Feb 28, 2014 | eMachines EL1358 AMD Desktop Motherboard...
Why cant mp pc recognize any monitors
Because the video card is defective. If the video card is part of the motherboard then the entire motherboard will have to be replaced.
Nov 13, 2010 | Computers & Internet
ASUS P4B not recognizing the display card
make sure you install the driver of your video card, and if still have the same problem try to use a diff workin video card, if you will be havinG the same issue if miht be the port of your motherboard where your display card is connected and it only means that the motherboard is faulty and you need to replace it
Jul 25, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Hi, I own a hp Pavilion Media Center a1600n desktop PC. Recently my motherboard stopped working. I replaced it with a gigabyte MA785GM-US2H. Here's my issue. The motherboard does not seem to recognize...
You may have tried this & I missed it.
For htis new cardto work, you need to DISABLE the on-montherbord video.
Go to BIOS Setup and you will find a spot where you can disable onboard video.
Now Mboard will recognize your new video card.
Jun 29, 2010 | Intel Motherboard
I think I burned up my video card. How do I recognize video cards I can/cannot use on my D856GBF motherboard? The original was a Radeon. The most recent deceased was a GeForce.
To know which of the video cards can be use and cannot be use... well try to connect your video card to your motherboard.. now turn on the cpu.. usual burned (deffective) video cards will cause the cpu not to boot and instead will make a beep codes...some video if they were successfully boot up will cause computer hanging during when the cpu is being used...some video cards will display lines and distracted colors on the monitor while the cpu is on..
This video card should not be used and needs replacement immediately so that it could not affect other hardware performance.
Much appreciated if you rate this help..thanks..
May 24, 2010 | Intel D865GBF Motherboard
I can't get my board to recognize my ATI Radeon x300 se in the pcie pnp will not even recognize it.
You must enter the bios menu and set the video controller to boot to the PCIe first. Save and exit the bios. The proper orders when installing a PCI-E card is as follows; before you install you’re new video card onto the motherboard. Install the graphics cards software. Than shut down the system. Install the video card. Boot system and enter the bios menu. Go to and open Advance.
Open North Bridge Configuration
See page 4-23 in manual.
Internal Graphics Adapter should be set to [PEG/PCI]
Internal Graphics Mode Select should be set to [Disabled]
PEG Port Control set to [Auto]
Save you're changes and exit the bios. You should be able to boot to you're PCI-E graphics card now.
Cheers'
Mike
Feb 05, 2010 | ASUS P5E-VM HDMI Motherboard
E machine wont recognize the moniter or keyboard
With the limited info that you provided, it seems like the motherboard is not functioning. When you turn the computer on, does anything happen in the box?
Jul 17, 2009 | Computers & Internet
AGP Video card for P4VMM2 motherboard
No it should recognize it strait away
You May have a faulty one
hope this link can help you thanks http://www.fonerbooks.com/r_video.htm
Regards; Aaron
Sep 16, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
MSI NX7600GT-T2D256E GeForce 7600GT, (256 MB) PCI Express Graphic Card Logo
268 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
