Question about Ngk Vehicle Parts & Accessories
Spark plug gap 1999 380 skidoo formula dlx what setting
What is the gap setting
jyackle5
  • 8197 Answers
SOURCE: spark plug gap setting 99 GTI
call your local auto supply store and they will tell you.
Posted on Dec 16, 2008
  • 196 Answers
SOURCE: Spark Plug gap settings.
Look on you're emissions tag under the hood they should be on there.
Posted on Jan 16, 2009
motor1258
  • 6674 Answers
SOURCE: GAP SETTING FOR 1995 CHEVY SILVERADO
4.3L = .045, / 5.0L & 5.7L = .035
Posted on Mar 22, 2009
  • 3567 Answers
SOURCE: spark plug type and gap setting please
I believe NGK brand is the best. Get the stock plug for your bike from the dealer. Gap should be 30 thousandths.
Posted on Apr 16, 2009
mamicheddy
  • 79 Answers
SOURCE: what is the gap setting for a 13hp honda motor
20 Thousands will work. If it does not, the you have other issues.
Posted on May 06, 2009
I have a 1991 skidoo tundra. And I have no spark. I changed the cdi box and swapped coils. What is the gap for the magnetic pick up also how do I test the magnetic pick up?
When in a pinch I have used a business card to set the gap, remember close will advance timing further will retard timing, unless you are a long way from the flywheel gap most likely not the issue but will affect spark intensity. Most likely bad pickup coils or weak magnets which requires flywheel replacement.
Jan 30, 2018 | Ski-Doo 2004 MX Z Renegade 800 H.O
2005 skidoo 600 with sdi. Starts dies in a couple of seconds will not go into high idle pulled plugs and there wet.
Likely one of two things
1) Bad spark quality, bad plugs, incorrect gap etc.
2) Lack of spark to the plug
Get a spark tester, cheap and easy at the auto parts store, and start there
Feb 20, 2017 | Cars & Trucks
Free manual for skidoo rotax 670 formula SS
Hi, Billy sorry you can't find the first and best tool you ever bought for your Skidoo despair not, for a mere $5 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day.
Ski Doo Snowmobile Service Manuals PDF Download
Skidoo Parts Free Shipping in for Ski Doo OEM Parts
http://www.operatorsguides.brp.com/operatorsguidesattachments/ownersmanuals_ssa/attach/04/1997/000798.pdf
95 formula ss 670 good sled
Feb 29, 2016 | Motorcycles
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
Spark plug gap size for 1991 formula firebird
See if you still have the Vehicle Emission Control Information label (the VECI label) under the hood on some radiator support member, probably. The spark plug gap is listed on it.
Feb 08, 2013 | 1991 Pontiac Firebird
Need do know the spark plugs gap
If you're replacing the spark plugs in your car engine, you'll need to set the gap before reseating the spark plug. The gap is the distance electricity arcs between the ground electrode and center electrode. The gap must be set correctly to ensure maximum performance. Here's how to set the gap of a spark plug.
  1. Remove the spark plug wires. Use a socket wrench to remove the spark plugs from their chambers.
  2. Clean the spark plug if you are not replacing it with a new one. Remove all dirt and debris from the spark plug.
  3. Check the owner's manual for your car (or any appliance with spark plugs) to find out the recommended gap setting.
  4. Use a gap tool to check the gap of the spark plug. Slip the tool between the ground electrode and center electrode. The gap tool should fit snugly at the recommended gap width indicated on the tool.
  5. Push the tool between the electrodes a few times to ensure proper gap. If the gap is too wide, push the ground electrode firmly against a flat surface to narrow the gap and then check again with the gap tool.
  6. Repeat Step 5 as necessary until you reach the correct gap. Reseat the spark plug and reattach the spark plug wires
Good Luck
Dec 10, 2010 | 1997 Pontiac Grand Am
Plug gap for 1999 380 touring skidoo
Most machines I have worked on with this plug set .018 to .020 inch
Nov 05, 2010 | Spark Plugs BR4HS Plug 10/BX #3322
My 98 skidoo mxz 500 keeps fouling spark plugs. why does it do this?
if it has a carb and is a two stroke check the gap on your spark plug and make sure your main jet is adjusted right. but it sounds like your sled is running to rich. look at the end of your spark plug, if it is black you are running to rick but if it is kind of a white color it is to lean. it should be pretty close to tan.
Feb 24, 2010 | Sport & Outdoor - Others
Vehicle Parts & Accessories Logo
Top Ngk Vehicle Parts & Accessories Experts
ken skalski
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
