Question about Bose 701 Main / Stereo Speaker
How to open bose 701 speaker
Toy cars inside the 701 speaker how can i open the speaker?
Reconnecting/retiring Bose speaker cones. Inside speaker I have four coloured wires....Red,Black, Green & Orange....which connectors do they attach to on the speaker cone?
Since you posted this in cars and trucks I assume this is a bose car system. Most bose auto systems have the amp physically attached to the individual speakers. This means each speaker needs the following wires +12v, 12v ground, + signal and - signal. It also means that the head unit cannot directly drive a non bose speaker. If you are replacing the speakers and bose radio the best thing to do is to run new speaker wires. You can reuse the factory ones if you can identify which ones are what...and that may be a pain. If the bose amps are ok and you want to replace the speaker you would need to leave them connected and wire the new speaker to the wires on the bose speaker that come from the bose amp. Depending on the specific bose system there may be an actual wire that runs to the speaker from the amp but on others the amp is directly connected to the voice coil leads of the bose speaker.
Oct 13, 2016 | Cars & Trucks
BOSE 701 Series I, How do you remove the top portion of the speaker to re-install the tweeter which feel off during shipment ?
if speaker is outside box then it should just sit back in the opening and attach with screws - most do = if it is inside the box, i have no idea
Feb 12, 2016 | Audio Players & Recorders
How to takwe apart a bose cinemate speaker
I wouldn't do it, because BOSE supposedly uses tubes to enhance the sound. Typically opening a speaker up creates scratches or breaks plastic parts.
Nov 17, 2011 | Audio Players & Recorders
Does bose 701 series ii have a fuse for power subwoofer?
Fuses are used to control the inflow and outflow of electrical current. They are mainly used in speakers in order to protect them from being blown out. This is why there is a specific number of ohms on the instructions that it can handle. I'm sure there is somewhere. There are fuses in all high quality speaker systems. You'd just have to open the back up in order to find it.
Jun 18, 2011 | Bose 701 Main / Stereo Speaker
My audio plugs had broke off, is there replacement parts and how much, mod# dv 7010
i lost speaker plug for bose 701 series ii so where do i find it
Aug 12, 2009 | Audio Players & Recorders
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
5.1 Home Theatre - PC
Its due to 2.1 channel sound input from your PC. Your Laptop supports only 2.1 channel sound so all the 5 speakers cant be played at a time! You need 5.1 channel input to work all 5 speakers
Dec 07, 2007 | Bose 701 Main / Stereo Speaker
Bose 701 Main / Stereo Speaker Logo
243 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
