Question about Nordic Track Incline Trainer X7i Interactive
Calibrating incline Incline stuck in highest position
  • 14 Answers
SOURCE: nordictrack apex4100i level incline will not work
Try this calibration procedure.
Turn the power switch on. Remove the safety key. Hold the Stop and Speed Up or Speed Plus buttons down then insert the safety key.
The display should show some numbers.
Press the stop key one time and the display should show some other numbers and some 00's. Press the Incline Up button and see if the Incline begins to move, if it does let it go all the way up and then all the way down, wait a few seconds after it stops, then hit the stop key 4 times. It should be calibrated. If it didn't move then the board or the incline motor is bad.
Posted on Jul 08, 2009
  • 103 Answers
SOURCE: Hello I have a Nordic Track A2050 treadmill and it
Hello there, The machine is attempting to do an incline calibration. Keep the unit lowered as you have it, reinstall the safety key, allow the unit to go all the way to the top and then all the way to the bottom. The machine will stop when at the bottom and the screen will go back to normal. The machine will not overtravel the incline motor and damage it. Just let the calibration finish the procedure and you will be fine.
Good Luck! Tim
FYI this will happen anytime the safety key is removed while the incline is moving on nordictrack brand machines.
Posted on Jan 11, 2010
maxtreadmill
  • 832 Answers
SOURCE: My treadmill is stuck in the max incline position
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
Posted on Jun 11, 2010
  • 218 Answers
SOURCE: my treadmill is stuck on
incline motor is bad or needs calibrated, try this
1. remove safety key
2. press and hold the speed+ and stop keys at the same time
3. Put the safety key in/on and release the keys
4. press stop once
5. hit the incline + arrow and let the incline go the whole way up and down
6. remove safety key and try
Posted on Aug 13, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Aug 31, 2015 | Nordic Track NordicTrack X7i Incline...
My New balance 1500 is stuck at the highest incline postion
Contact manufacturer, sounds like a defect with machine.
May 06, 2014 | New Balance Balance 1500 Treadmill
The incline is stuck in the highest position
Try recalibrate. If that dont work, replace the incline motor.
  1. Press speed^ and stop simultaneously
  2. Insert key
  3. Press stop once
  4. Press Incline up
  5. (This should recalibrate incline). If this fails, replace the incline motor.
Dec 31, 2013 | Proform Perspective Es Treadmill PFTL99806
Incline position stuck fully raised.
lube the rack and pinion, and adjust the small POT. see the diagram attached.However RUN the software calibration for easy troubleshooting and fix it. God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif3955270e-0ffb-4d9b-b5ae-29087a8d6aec.gif
Apr 04, 2013 | Exercise & Fitness
Horizon treadmill model ls925t will not allow the grade to be adjusted. It is stuck at the highest grade
RUN THE SOFTWARE CALIBRATION. God bless you
Apr 02, 2013 | Horizon Exercise & Fitness
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
My treadmill is stuck at the highest incline and will not decline
Although it is fairly rare the incline motor can jam up into the highest position and get stuck there. To fix this take off the plastic hood that covers the incline motor and depending on the motor you should be able to wind it with your hand out of the highest position. When it is out of the highest position run the calibration as described in the owner's manual and it should go all the way up and all the way down. If it is not this type of motor that can be wound by hand then the first and last thing to do is to try calibration of the incline as described in your manual. If this does not work then a new incline motor is needed.
Dec 31, 2009 | Proform Quick Burn Pro Treadmill with 12...
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Aug 11, 2009 | HEALTHRIDER S300SE TREADMILL Drive Motor
Treadmill incline stuck @ steepest level (highest)
MAKE SURE YOU STAND TO THE SIDE OF THE TREADMILL WHILE PERFORMING THIS
1)Connect the wall power to the treadmill
2)Remove the safety key
3)Hold down the red stop button and red increase speed button (this is the red triangle next to the start button)
4)Insert the safety key while holding both buttons down in step3
5)The treadmill will now go into a diagnotstic calibration mode
6)Let go of both buttons in step 3 and press the oval stop button once
7) Now press the up arrow green incline button once(This is located to the left of the yellow program button)
8) Allow the treadmill to go through a calibration cycle, once it completes and stops moving remove the safety key count to 3 and reinsert.
Jan 08, 2009 | Exercise & Fitness
Nordic Track Incline Trainer X7i Interactive Logo
105 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
