Question about Pyle PLDN74BTI Car Video Player
Which installation kit is correct for the pldn74bti
Doesnt fit in hole, the one I purchased will not fit over the radio face and I dont want to cut on it.
Took radio out, but when put back in it does respond still has power to it just nothing responds
Is it a detachable face???? if so take face off and look for a reset button on radio itself
Apr 04, 2012 | Ac Delco AM-FM Radio Cassette
I just purchased a BV9998B audio system- but it doesnt fit in my 1998 Jeep Grand Cherokee.... any solutions? suggestions?
You need a wiring kit and a faceplate kit. If those can be had your in the clear as far as it WILL fit. When pulling out the radio pay attention to the mounts and wiring pigtails(bundle) including the plugs. If you can find matching plugs and decent mounting hardware and face plate your good to go. If the body of the Bose is bigger than space it has to mount into your in trouble. If you must cut the dash that is a whole other ballgame. Hope that helps..
Jul 20, 2011 | Boss BV9990 Car Video Player
How do i remove face plate around the radio it has i think four small holes but i dont know what to use or what the holes are for
You need a tool like this. Insert the keys in the holes on the right and left sides of the radio. I believe you have to pull outward on them slightly and the radio will slide right out. You can also try with a cut up wire hanger that's bent in a u-shape. I hope this helps. Let me know if you have any other questions.
Thanks,
Ray
Jun 16, 2011 | Mercury Appliances 2002 02 Mercury Sable...
I WANT TO INSTALL A 7" DOUBLE DIN RADIO. WHAT CAN I USE AS THE FACE PLATE AROUND IT?
i [iece of Plexiglas, use a piece of card board to measure out the area and cut it to size. install and mare the area the radio will fit in. cut that out. now you have a template in your hands. take this to the shop your getting the Plexiglas from and have them cut it for you to shape. and put a piese of tint on the back (black works great or titanium". now remove the radio, remove the dash shield, install the plexi, hot glue will do or drill a few holes and screw it in. install the radio and dash shield. There you go a fully customized system.
May 06, 2011 | 2001 Jeep Grand Cherokee
Removal of radio 2006 e450
you should see 4 holes on the face plate find a nail that fits in the hole push them inand leave them in. if you released the catches the radio will slide out
Feb 01, 2010 | 2005 Ford E-Series
I am trying to find out how to pull the radio out of the dashboard to see if my antenna is disconnected...or where in the fender well I should look also?
if it is not a factory fitted radio ther should be 2 holes in eatch side of the face of it. you can normaly buy the tool from any moter shop but if not get a wire coat hanger cut 4 lenghs the size of your finger push them in each of the holes then pull it out.
Sep 23, 2009 | 2003 Honda Accord
Double din radio doesn't fit in dash
i have a 2002 ford escape and i bought a double din radio and it did not fit and found out it is actually a din and 3/4 with out serious mods (cutting a bigger hole in dash) double din wont fit i bought a single din stereo and a din a 3/4 dash kit works fine
Jun 10, 2009 | 2003 Ford Escape
Could someone please give me a simple (I'm auto mechanically challenged) step by step instruction on how to install a new radio in my Ford Windstar. It is a 1996 and the stero I am putting in is a Naxa NX...
Typaclly if you purchased the faceplate install kit, and harness kit, the install will be very easy. You will also get a set of instructions for each kit.
The first hurtle you will have to leap will be removing the old radio, this requires a set of removal tools that fit into the four holes in the face plate of the stock radio. This set may include 2 to 4 tools to put into the holes to unlock the unit, once you have it out, install your harness kit, faceplate and stereo.
Hope this is of some help.
Ed
Apr 17, 2009 | 1996 Ford Windstar
I need to replace the stock shaft radio with a brand new aftermarket head unit. NEED HELP!
is this a post raido or flat face? flat faces will have din pins 2 hole each side of raido have to get a tool to remove --also get wire adp. frm parts store will b -easy that way
Apr 17, 2009 | 1986 Ford F 250
Adding a remote USB port
I solved my own problem.1 I removed radio1.gif face 2 I removed back cover of radio face to expose USB solder joints.3 I drilled a hole in the back cover of radio face over solder joints 4 I drilled a hole in front cover of radio behind face plate and lined it up with hole in back cover of face plate.5 I cut the male plug off of a USB extension cord and ran it through factory notch on the back of radio,through drilled hole on front panel of radio, thruogh drilled hole on back cover of radio face and soldered wires to back side of USB plug in. Wire colors from top to bottom are Red, White, Green, Black. Solder sheild to any of the three larger solder joints next to these connections. Make sure wires are not touching any other connections. Put radio back together and add screw that locks face to radio. Face can no longer be removed with this wire added. Now I can plug in my 8gb memory stick1.gif,hide it under the dash and have a clean looking installation.
Jan 17, 2008 | Kenwood KDC-MP435U CD Player
Pyle PLDN74BTI Car Video Player Logo
15 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
